2,4S wristpin length ? will machine a T-pin
What is the length of the 2,4S mahle piston wristpin? and wath sort of lockingclip shall I use? I have and old set of pistons but the wristpins are gone, the machineshop will make a new set of a set of T- piston pins.
//Henrik
SWEDEN
Old 01-04-2005, 12:11 AM
Originally posted by Wayne at Pelican Parts
Just find a used set - these never really wear out, and you can probably get them for free from a helpful Pelican board member.
-Wayne
I have a set of wristpins from a T engine and will "cut! them to the correct length to fit in the S-pistons..
Old 01-04-2005, 03:13 AM
Is there anybody that have a S - 84mm wristpis that could messure the length?
Old 01-06-2005, 09:43 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The 2.4 T and S (and 2.2 T,E and S for that matter) all used the same wrist pins. They should be interchangable without any trouble.
Also you can get the wire clips from out host.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-06-2005, 10:18 AM
Bill Verburg's Avatar
Im not sure, but the Mahle 89mm and 90mm use for 2.5 and 2.7 upgrades both had 22x58mm wristpins
Bill Verburg
Old 01-06-2005, 12:36 PM
