jluetjen's Avatar
neilca; You're right and I'm -- well -- nuts!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-13-2005, 10:17 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The 2.2 rod is an update to the early rod and was designed to be stronger and it is. For all of you who prefer 2.0 rods to 2.2 rods we have 30 sets and we would be happy to trade any good set of 2.2 rods for 2.0. We also have 2.0 "S" rods to trade or sell.
Sometimes you give up weight for strength.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-13-2005, 10:49 AM
neilca's Avatar
Henry,
What is different about the "S" rods?
Old 01-13-2005, 02:19 PM
"S" rods are nitrated.
Henry Schmidt
Ph: 760-728-3062
Old 01-13-2005, 03:12 PM
3 restos WIP = psycho
kenikh's Avatar
What does the nitriding lend to the characterstics of the rod. I can understand cranks, but rods?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-20-2005, 09:02 PM
Nitrating helps to prevent surface cracks that lead to catastrophic rod failure. The effect is similar in purpose to the shot peen process used by many American V8 engine builders. Some people even believe that these processes add overall rigidity to the rod.
Henry Schmidt
Ph: 760-728-3062
Old 09-21-2005, 08:20 AM
kenikh's Avatar
Interesting; so would you say nitrided rods 'S' rods are superior to conventional 2 liter rods for the purposes of building a high reving short stroke motor? Can conventional rods be shot peened to the same effect of nitrided 'S' rods?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-21-2005, 08:44 AM
Addicted to Racing
edbaus's Avatar
Or,
would you still shot peen a nitrited rod, or does that not work/no benifit.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 09-21-2005, 08:52 AM
I'm not certain.
I would guess that shot peening is less affective.
The shot peen process only puts a very thin layer of surface material in compression to help redistribute stress.
Nitrating hardens the surface as much as .020 deep creating far more stress resistant surface.
* Please remember that I am not an engineer just a lowly mechanic and that the opinions stated here are only from my somewhat limited experience. *
Henry Schmidt
Ph: 760-728-3062
Old 09-21-2005, 08:55 AM
kenikh's Avatar
Hmmm; I am considereing non-nitrided 2 liter rods for a motor build and want opinions on whether they would be sufficient for a motor that would spin to 7800 RPM.
Henry, have you or would you build a motor like this on these rods?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-21-2005, 09:02 AM
The controlling factor for Supertec is piston weight.
A high performance SS 2.8 piston (95mm) generally weighs at least 100 grams more than say a 2.0 piston (80-81mm). With the heavier pistons we run the 2.2 rod. It (the 2.2 rod) is heavier but far stronger.
We have both in stock for sale.
Henry Schmidt
Ph: 760-728-3062
Old 09-21-2005, 09:24 AM
Addicted to Racing
edbaus's Avatar
Talked to my metalurgist. He is also a drag racer, so he understands these concepts. He has never heard of nitriting rods and feels that the advantages of the nitriting (which is usually used to help with wear resistance) would be less than shot peening. Shot peening, he feels, would do a better job of stopping crack propagation
He also went on that the shot peening a nitrited part may diminish any advantages the nitriting had becasue it would disturb the very thin layer of nitriting.
Overall, he would rather have a shot peened rod than a nitrited. He is not sure of where the nitrited then shot peened would fall.
Ed
Old 09-21-2005, 11:22 AM
Shot peening, he feels, would do a better job of stopping crack propagation.....
Ed
Opinions do vary. That's what makes a car race.
Porsche Nitrited the rods, we know that. I wonder why your guy doesn't know that?
Some people race in a straight line for 5 seconds, others race in all directions for 24 hours. To each his own.
Henry Schmidt
Ph: 760-728-3062
Old 09-21-2005, 11:51 AM
Addicted to Racing
edbaus's Avatar
We are not a Porsche shop. We make various products (mostly high precision turnings in high production) for the auto industry.
His expertise is in metallurgy. All things metal and the heat treat of them. He is in charge of our heat treat department and development of new products. It is not in Porsche specifically. His only knowledge of Porsche is what I tell him.
Nitriting rods on a production basis is much faster and much cheaper than shot peening. Shot peening lines can be set up for production (I quoted on installing one for torsion bars for power steering applications) but it is much more specific. I was looking at volumes more like 5 million parts, not 50,000 parts. Would not be cost effective vs doing by hand.
Ed
Old 09-21-2005, 01:11 PM
Author of "101 Projects"
Wayne 962's Avatar
The early Porsche spec book does indeed say that the 911S rods are "seft nitrided." However, the 1969 book simply says "forged steel, (stress-relieved).
These books contain lots of typos and errors (which I found out while I was writing the Engine Rebuild Book), so I wouldn't necessarily believe 100% of the stuff written in there...
-Wayne
Old 09-22-2005, 12:49 AM
Nitriting is a process that can be identified visually. The books have a great deal of good information but sometimes experience can answer questions the books can't.
Please remember that Porsche was a very small company that did not always have perfect internal communications.
I think this is something the concourse fanatics seem to forget. Written in a spec book or on a brochure was not always how a car or part was delivered.
Henry Schmidt
Ph: 760-728-3062
Old 09-22-2005, 09:23 AM
What about SS 2.6 piston (92mm RSR)? Is it safe to use 2.0 rods for this?
Old 09-22-2005, 09:48 AM
We would use 2.2 rods for that aplication.
Henry Schmidt
Ph: 760-728-3062
Old 09-22-2005, 09:57 AM
speedingbullitt's Avatar
2.8rsr piston
would an earlier rod such as the 2.2 be prefered over the 2.4/2.7 rod for the 92mm rsr pistons?
Old 09-22-2005, 11:14 AM
Re: 2.8rsr piston
2.4 -2.7 rod has a different bearing size and will not fit a 2.0-2.2 crank.
The rod lenth is also shorter on the 2.4-2.7 rod.
Henry Schmidt
Ph: 760-728-3062
Old 09-22-2005, 11:47 AM
