-   -   rering 964 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/201035-rering-964-a.html)
stevepaa 01-11-2005 01:49 PM
rering 964
1992 C2 tiptronic with 16500 miles had low compression and significant blowby on valves due to valve guide wear. Disassembled entire engine for the fun of it. Heads done by Ted Robinson. Cams by Elgin. Crank is perfect. Cylinders still show hone marks, pistons show slight discoloration on skirts. Should I hone and rering or just put it back together?
camgrinder 01-11-2005 05:01 PM
What caused the valve guide wear in such a short time?
stevepaa 01-11-2005 05:02 PM
oops, 165K miles
camgrinder 01-11-2005 05:08 PM
Oh thats different.
ChrisBennet 01-11-2005 05:57 PM
Don't hone it. Just clean it with some Scotch Brite and soapy water.
Henry shared the results of his experiments in thread: do I need to hone this?
-Chris
Wayne 962 01-11-2005 10:26 PM
The 3.6 engines have valve guide wear problems. I would definitely inspect and replace the rings if they are out of spec.
-Wayne
stevepaa 01-12-2005 08:39 AM
thanks, I missed that discussion thread in my search.
