rering 964
1992 C2 tiptronic with 16500 miles had low compression and significant blowby on valves due to valve guide wear. Disassembled entire engine for the fun of it. Heads done by Ted Robinson. Cams by Elgin. Crank is perfect. Cylinders still show hone marks, pistons show slight discoloration on skirts. Should I hone and rering or just put it back together?
What caused the valve guide wear in such a short time?
John Dougherty Dougherty Racing Cams |
oops, 165K miles
steve old rocket inguneer |
Oh thats different.
Irrationally exuberant
Don't hone it. Just clean it with some Scotch Brite and soapy water.
Henry shared the results of his experiments in thread: do I need to hone this? -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Author of "101 Projects"
The 3.6 engines have valve guide wear problems. I would definitely inspect and replace the rings if they are out of spec.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
thanks, I missed that discussion thread in my search.
