could someone look at this and tell me what you think
exhaust valve with 115k miles
Old 01-14-2005, 06:43 AM
Still Doin Time
asphaltgambler's Avatar
What's the problem?? looks as if it is running lean and or fuel additives for the coloration
Old 01-14-2005, 07:18 AM
Super Moderator
cstreit's Avatar
Lean... ...or possibly race gas.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-14-2005, 07:30 AM
no problem, just wanted to see if all that white coloration means anything, I'm a novice about engines. We're putting SSI's on, and I wanted to learn more. So I thought I would ask. Thank you
Old 01-14-2005, 07:36 AM
Tim L's Avatar
What do the other five look like?
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 01-14-2005, 10:44 AM
KCPSG's Avatar
the other look nearly the same except for #6 it is not nearly as white...we didn't really think there is a problem,but we wanted to make sure that these looked fairly normal for a 100k mi. car.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 01-14-2005, 02:42 PM
audi2.7t's Avatar
How do the plugs look?, SSI's might worsen an already lean condition... I for one don't like white valves or plugs in my motors.
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 01-14-2005, 08:54 PM
Author of "101 Projects"
Wayne 962's Avatar
White is typically lean, but not always. Lean is a bad condition for a 911 motor, if anything you want them running on the rich side. When the car is running lean, it will tend to run hot, which can lead to all sorts of problems. Here you see a valve that probably runs very hot...
Have your mixture checked with an O2 meter like this one:
http://www.pelicanparts.com/catalog/shopcart/MISC/POR_MISC_INNOVT-detail.htm
-Wayne
Old 01-14-2005, 10:33 PM
