2.2 race motor rebuild
I am about to rebuild my 2.2 for Tarmac rallying.
My plan is top obtain as much HP as possible with out having a motor that needs to rebuilt every other month. So I would like some input on the configuration.
The class rules require me to maintin the same injection and single plug ignition.
Motor 2.2S MFI
Boat tail case
Knife edge crank
JE Pistons 10.3.1
Nickies
S cams
opened up ports
SSI heat exchangers
Eurometirx 38mm throttle bodies
2.2S MFI Pump
Has anyone got any ideas on what sort of HP I should be looking at and also who has run a similiar combo
thanks in advance
Michael
Old 01-13-2005, 03:31 PM
jluetjen's Avatar
opened up ports
From what starting point? The early (2.0) factory rally cars used a 2.0T heads with S cams. If you already have 2.2S heads, I wouldn't open them up any further. If you have 2.2T or E heads, you might want to consider keeping them as is (to save some cash) and smooth the mid-range some.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-13-2005, 04:03 PM
Navin Johnson
TimT's Avatar
close to 190-200 hp
I have a very similar engine
'69 911 GT-5
'75 914 GT-3
and others
Old 01-13-2005, 04:17 PM
Michael, I was under the impression that you were allowed Twin Plugs for LMS?
Mark
Sydney
Old 01-13-2005, 04:21 PM
camgrinder's Avatar
Can you change the cam? Or will you be penalized with weight?
John Dougherty
Dougherty Racing Cams
Old 01-13-2005, 04:24 PM
Mark,
Plan on running the car in SS.
Cam grinder cams can be changed what would you recommend.
Michael
Old 01-13-2005, 05:24 PM
camgrinder's Avatar
I would use my dc60 grind, especially with 10.3-1 compression.
With your combination, the powerband would be 4500 to 7500.
At least 15+ hp more than the S cams.
John Dougherty
Old 01-13-2005, 05:38 PM
Hey John I would like to thank you for your quick shipment of my cams and great technical assistance. Those are 2 things you do not find in the Porsche world. Thanks again!
Eric Hood
Old 01-13-2005, 05:50 PM
camgrinder's Avatar
Your welcome Eric.
John Dougherty
Old 01-13-2005, 05:57 PM
Michael, it might be worth checking on the legality of boat tailing and knife edging. My reading of the regs is that this is not on for SS. Might save you some aggro down the track...
Mark
Old 01-13-2005, 06:13 PM
Mark,
Checked the regs are they say you can remove metal not add.
I am trying to ensure the car is built to be above all reproach.
My view is that I am rebuilding the car from the ground up so I can incorporate all the necessary modifications whilst ensuring the car will have no problems in running in SS for Targa Tas and classic Adelaide, as well as being able to be used for group SC historic races.
Michael
Old 01-13-2005, 06:48 PM
Michael, here are the regs for SS engines from 2004 Classic Adelaide. I don't want to be a wet blanket but I can't see anything in here that would allow boat tailing or knife edging. Given the aggro caused to a number of Porsche guys in the past, I'd strongly reccommend getting a ruling to remain above reproach. Also, 10.3:1 ??? C/R.
QUOTE...
The original engine specification as supplied by the vehicle manufacturer for the make and model
concerned, must be employed. Mechanical modifications are forbidden except for the following:
(i) overboring is only permitted within the manufacturers normal specified reconditioning
tolerances (this is generally restricted to around 0.5mm increase in diameter).
(ii) pistons are free, however they must be dimensionally the same as original, except for the
diameter, which is only allowed to be varied as per (i) above.
(iii) reconditioning of other engine components within the manufacturers' specified tolerances
is permitted.
(iv) the original head may be modified by the removal of metal only. The valve sizes must
remain standard. The compression ratio must remain as standard.
(v) camshaft timing and lif t is free.
(vi) for rotary engines, the only allowable modification is "extended porting". In addition, the
exhaust port inserts must remain standard and in their normal place. "Bridgeporting" or
"peripheral porting" is not permitted.
(vii) the original ignition system must be retained save that 'pointless' distribution operation
may be substituted for breaker points. Freedom of mechanical and vacuum advance
mechanisms is allowed, as is freedom of ignition wires, spark plugs, etc.
(viii) turbochargers or superchargers, if fitted as original equipment, must remain standard, as
must the method of controlling boost or pressure. The amount of boost or pressure must
be standard as specified by the manufacturer.
(ix) the complete original induction system must be retained, without additions or deletions.
The components which control the quantity of fuel entering the combustion chamber may
be modified, provided that they do not have any influence over the quantity of air
admitted. Replacement air filter cartridges are permitted as long as they fit into the
original air cleaner(s). Additional air ducting is not permitted. Fuel pumps are free.
(x) the exhaust system is free past the point of entry into the first muffler. The exhaust pipe
must exit at the original point on the vehicle.
(xi) engine liquid cooling systems (ie water and oil) must remain as standard, although the
radiator may be replaced by one of the same size, but of greater thickness. The original
cooling fan(s) must be retained unaltered, but one additional electric fan may be added.
Thermostats may be removed.
(xii) air cooled engines must retain the standard system, although the speed ratio may be
changed.
(xiii) ancillary items such as starters, generators, etc., may be uprated, provided that the
original type is respected.
(xiv) clutches may be uprated only by the changing of springs, diaphragms or linings, however
the remainder of the clutch assembly must be original.
(xv) engine sumps may have internal baffling but the sump shape and capacity must be
standard.
END QUOTE...
Thats it........
Old 01-13-2005, 07:02 PM
Mark,
I see your point.
I note at point (iv) for heads metal is allowed to be removed.
Compression ratio well from my research if I was to remove metal from the head the CR would increase so I dont see a problem with that area.
Point (iv) may require some clarification as they say metal is allowed to be removed and then they say CR must remain as standard go figure the logic.
I n any event I am not super concerned about the CR in the motor or the Final HP as my plan is to build this car and run it for a considerable amount of time and events.
I have had my fill of having modified cars that need to be continually changed I would like to learn to drive this long hood at ten tenths on teh track and 7/10ths on tarmac rallies.
My experiences with rallies previously was not a pleasnt experience as the navigator caused me a bit of angst. He was to busy trying to get ***** faced at teh pub each night and I never could be sure that he would turn up the next day and or fail the breath test.
Michael
Old 01-13-2005, 07:30 PM
Michael,
My feeling is that whilst the time advantages are attractive for SS, it's just too restrictive. I feel that LMS provides enough scope to build a fun, reliable rally car without going crazy. I have a 2.7 (in a 914/6) giving about 220hp, really understressed power from 4000 to 7000rpm. The problem is the regs changed after I built the engine (aluminium cases) and I have to start over. I'll probably build a long stroke 2.5L but haven't made a final decision.
Quote: My experiences with rallies previously was not a pleasnt experience as the navigator caused me a bit of angst. He was to busy trying to get ***** faced at teh pub each night and I never could be sure that he would turn up the next day and or fail the breath test.
Bummer! I wonder what the penalty is for murdering your navigator?
I guess I've just been lucky thus far. I'm in preparation mode for Rally Tasmania next month.
Cheers,
Mark
Old 01-13-2005, 07:55 PM
Mark is your 914/6 car the one prepped by PR.
I think Ryan also got caught with the reg change on Alum cases and had to build a new motor. I heard he is doing it again.
Hence why I think SS is the way to go a low stressed engine and with the age of my car I dont get any headaches of wide tyres rubbing on teh bodywork and all that stuff.
I would really prefer to be runninf a 2.0S 69 911 however every one I looked at was a POS. so I bought this 2.2 which If at a later point I wanted to run in LMS I can easliy built an additional motor say 2.4or 2.5 short stroke for the rallies.
I suppose I don't want to go to the hassle of stuffing around with brake bias and different brakes I see that SS I can use genuine parts and not have to worry.
Michael
Old 01-13-2005, 08:05 PM
Michael,
Quote: Mark is your 914/6 car the one prepped by PR.
Yes, the yellow one.
Qoute: I think Ryan also got caught with the reg change on Alum cases and had to build a new motor. I heard he is doing it again.
Yes - dropped a valve in Adelaide
IMO, a 2.2S running in standard spec should be a good combination. The way I see it (and to get this thread back on its original track) is what can be done to a 2.2S within the regs above
A 2.2S is already well optimised. You might get higher compression by messing with deck heights etc but I doubt there's much in it as it's already 9.8:1
The valves and ports are already comparatively large - probably the biggest restriction on getting it to suck more air are the throttle body diameters which cannot be altered under (ix), although others with more knowledge than me might want to comment?
Cam profiles are probably the biggest item of potential gain - this list is your friend
In the final analysis, you might get 190-195hp without going to the expense of boat-tailing, Nickies, knife-edging etc (which the gurus on this list consider pretty much worthless for most engines anyway).
Just MHO - best of luck with your project.
Mark
914/6 2.7
Old 01-16-2005, 02:31 PM
Mark,
Thanks for your input.
The reason I was going to use Nickies is two fold the first being my existing Pistons and Barrels/Cyclinders are shagged and secondly they are also 30% lighter.
As I have read and reread the rules I see that I am allowed a variance of some +/- 5% weight on the total car. If you allow that the cage will add 80+ kilos and then you need to save that same amount of weight somwhere else.
As I cannot use fibreglass panels weight becomes the enemy.
Michael
Old 01-16-2005, 03:36 PM
I've heard that the Nickies are a good product (I didn't mean put them in the 'worthless' basket with boat tailing etc) and if you need to replace your P&Cs and you see the value, then fair enough - but it's a lot of $$$ to save a few pounds...
80 KILO ROLL CAGE (175lb)? Did you find some left-over Sydney Harbour Bridge girders somewhere?
Cheers
Mark
914/6 GT (Repro) Tarmac Rally car
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 01-16-2005, 03:48 PM
Mark,
I talked to Bond roll cages and they said that a six point cage would end up approx 80Kg.
Do you think the cage should be lighter.
remember that there would be more tubing in a 911 thana 914/6 (bigger cabin)
Michael
Old 01-16-2005, 03:54 PM
Michael,
Quote: Do you think the cage should be lighter.
Don't know - it just sounds excessive. Mine is made from chrome-molly and was built to stiffen the chassis in addition to its safety role so is braced forward and aft into the engine bay in several places. I wouldnt' have thought there would be much more tubing required in a 911 - but what do I know? FWIW mine weighs 46KG and I thought that was OTT.
Mark
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 01-16-2005, 04:12 PM
