Increasing compression?
Is it possible to increase my compression just by shaving the heads. I have a 1978sc and would like ot do a few more mods. Maybe go to twin plugs also.
Old 01-26-2005, 03:39 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: Increasing compression?
Yes, milling the heads will increase the compression ratio.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 01-26-2005, 03:53 PM
How much could I get away with on a stock sc. And go to twin plugs. Still have cis and engine has 964cams .
Old 01-26-2005, 03:55 PM
Irrationally exuberant
ChrisBennet's Avatar
You won't need twin plugs for the small compression increase you would get from milling the heads. If you have the budget for twin plugging (an expensive proposition) I'd spend it on 98mm P&C's and make a 3.2 instead.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-26-2005, 04:17 PM
