Gon fix it with me hammer
svandamme's Avatar
heads and camhousing
When rebuilding the engine, everything fresh
Wayne's book says put the heads on the engine
then the camhousing
but if you're doing a valve to piston clearance check , you need the whole assembly on and off a couple of times
does anyone assemble the heads, and the camhousing as a unit
then puts it on as a unit?
i know some folks disassemble and engine that way , but can you reassemble it like that? any drawbacks? reasons not to do it this way?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-20-2005, 02:03 AM
Irrationally exuberant
ChrisBennet's Avatar
I don't do it that way (heads+cam towers as a unit) but I think the most engine builders do. The reason I mount them seperately is because I like put a straight edge across the tops of the heads to check that everything looks even after I torque them down.
Tip:
If you torque the heads and then attempt to put the cam carrier on, the studs/pin on the heads may not be perfectly aligned with the holes in the came carrier because on some motors the heads can "float"/move around a little on top of the cylinder.
To get around this, I lay the cam carrier on the heads and snug up the head stud nuts (enough that the heads aren't going to move around). Then I take off the cam carrier and torque the heads.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-20-2005, 07:33 AM
OCD project capitan
BigD9146gt's Avatar
Hey Stijn,
I rebuilt the top end of a 78 911 a few months ago and thats exactly how i did it. Took the cam housing/heads off as one unit and installed them as one unit. I didn't see any drawbacks from doing so, and as Chris pointed out about the head hight, if you measure it all first there shouldn't be any problems. I liked doing it off the engine because it allowed me to sit at my bench and install all the rocker arms and rocker shafts. I don't think its a matter of good/bad, more or less preference.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 01-21-2005, 01:40 PM
svandamme's Avatar
sweet, then that's how i'll do it... like you said don , you can do it at a table, sitting down
thanks for the replies
Stijn Vandamme
Old 01-24-2005, 01:00 AM
