Red face I'm have problems removing the 5mm rocker arm hex screw and nut
Before I do anything dumb, can someone please give me some advice on how to proceed. I have already removed all my other rockers except one, fortunately it's on the end and not in the middle. The barrel nut is facing outward, I believe the 5mm hex bolt may be rounded slightly so it won't grab very well. I soaked it well in break-free on both sides hoping this will help to loosen it up. Advice please! Thanks for your time and help.
Best Regards,
Alex
When in doubt, stop and put pride aside and ask!
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 01-21-2005, 09:03 PM
magic930's Avatar
The bolt is probably toast anyway if it isalready rounded so you can try and tap/jam a 12point in it. I had a few that needed this method and a third that I drilled out. New bolts are cheap!
Old 01-21-2005, 09:29 PM
Thank you Majic930, I'll give it a try.
Best Regards,
Alex
Old 01-21-2005, 09:37 PM
cheap allen wrenches are soft, and round out easily. i use a hazet 5mm 1/4"drive allen socket and ratchet for decent leverage. be sure the allen socket is completely seated. tap it in to be sure. you can only loosen the rocker bolt by the 5mm end.
206 637 4071
Old 01-22-2005, 08:55 AM
Friend of Warren
Sounds like the same one I ended up having to drill out.
Kurt V
Old 01-22-2005, 06:46 PM
Got it! Thank you Gentlemen
Thank you all for your advice and tips, I successfully removed the last nut. It took a long extension and a good Craftsman 5mm hex that I gently tapped in and slowly broke it free.
Best Regards,
Alex
Old 01-23-2005, 08:09 PM
