-   -   3.2 going in right direction? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/204721-3-2-going-right-direction.html)
drums 02-04-2005 05:55 PM
I don't have any place to turn for advice, so you guys are it. The local Porsche mechanic is 'old school' and doesn't believe in modifications. He is good but I will have to send all modification machine work out.
This is my first engine enhancement ever and I don't attempt any mechanic duties, period. I do have a brain and think I have come up with a good, sturdy engine modification design. Here goes....
It is an '89 3.2 and needs a rebuild. I plan on having EBS Racing bore the cylinders to 98mm, replate/Nikasil, JE pistons [from 9.5:1 to 9.8:1CR]. EBS Racing will take the heads apart, install new exhaust valves, install new valve springs in and out, polish exhaust port, drill for twin plugs [California gas, 98mm pistons],
964 cams [exchange].
The case will be boat tailed, the crank knife edged and balanced,
the Motronic system will stay in place and be enhanced with a '911Chips', GHL exhaust headers [complete kit], turbo oil restrictor upgrade, the throttle body will be honed and polished and the intake manifolds will be extrude honed, also.
The twin plug system will be operated with a 964 distributor and
a 'splitter' from Andial.
The only nagging question I have are the 964 cams. With this set up, will I be restricting the engine in any way? Don't forget-I live in the most restrictive smog state in the union. I know the 964 cams will pass smog.
Wayne alluded to the fact [in his book] that the smog laws are more stringent than what some cars were designed to perform. A case in point is mine-the state max on hydrocarbons is 120. The owners manual for my car states less than 330! With just at 200,000 miles, I was 120 [on the 'smog only'] when put on their dyno smog machine.
Thanks,
Drums
350HP930 02-04-2005 06:11 PM
Unless you are planning at running that thing at redline all day long the boat tailing and crank work is money wasted IMHO.
I also don't believe in restricting oil to the heads since that oil flow helps to keep CHT temps down.
Everyting else sounds pretty good though.
Some of the california guys can give you some better advice on what the most radical cam you can get away with is.
ChrisBennet 02-04-2005 07:03 PM
I 2nd 350HP930's excellent advice.
I've done a 3.4 twin plug conversion. If you are going to twin plug it, go for 10.5:1 compression. Otherwise you are giving away horsepower. 9.8:1 is the upper limit of single plug so twin plugs are not doing really anything for you.
-Chris
Doug Steinel 02-04-2005 07:04 PM
Why the twin plug? Usual rule is if CR < 10.0, single plug is fine.
drums 02-04-2005 07:31 PM
Hi Braun and Chris,
As Wayne explains it in his book, 98mm is the outside diameter capability of single plugs. With California gas being so weak [91 octane, max.], the restrictive smog laws [they are only going to get worse] and the diameter limit, I want to err on the safe side and make sure ALL of the fuel gets burned. With twin plugging, you can tweak the timing to fire at the optimal position in the piston stroke [and it helps to keep things cooler].
Hi 350hp930,
Thanks for the boat tailing/knife edging advice.
As for the oil restrictor upgrade, I thought [through Waynes' book] that it actually helped things run cooler by increasing pressure to places that needed it, otherwise why would it be called an 'upgrade'? I will read that section over again.
Thanks guys!
Drums
350HP930 02-04-2005 08:00 PM
From what I have heard the mod was made to boost oil pressure.
I have never had any oil pressure problems that need to be corrected so I am more concerned about not restricting the flow of oil to the heads.
If memory serves me correctly it was a mod that was made to stock motors. In the case of a hot rod 911 head cooling becomes a priority.
Carrera3.5L 02-04-2005 09:30 PM
You can search my 3.2L to 3.5L engine build threads for some ideas. As you will find when your engine is completed, the power output can be quite good provided you get away from the std. heat exchangers and run a better exhaust. 255-265 crank horsepower is realistic for a street 3.4L twin-plug motor with the right modifications.
You WILL NOT get away with any more then 10:1 CR with 91 octane, even with twin plugs. 9.8:1 and twin-plugs will be a good, safe combo for 91 octane. Don't believe me? Talk to Andial. They will tell you the same thing. I have 9.5:1 CR in my 3.5L and have a special Steve W chip that retards the timing even more when the weather gets hot so the motor doesn't ping. Version 1 makes 239 at the wheels and Version 2 makes 246 at the wheels.
Your engine build plan sounds pretty good. I would really twin-plug regardless of compression ratio with the bigger bore for the extra safety margin it provides. Modesto can and does get awfully hot in the summer.
A 3.4L twin-plug with extrude honed plenums, bored throttle body, custom Steve Wong chip, SSI's or headers and 964 or Web 20/21 cams will make for a very nice and driveable street car. Either cam set listed above will pass CA smog. Obviously, SSI's or headers will not but putting the heat exchangers on every 2 years for the smog check and then back off takes a 1/2-3/4 day.
I went against the advice of the "experts" on this board and shuffle pinned the case after seeing a whole row of 3.0L and 3.2L cases at Ollies' Porsche Machining that were damaged due to case movement. George and Ike probably see more machine work then anyone else in the country and they also do the machine work for Andial and Porsche Motorsport. Both have been around for over 25 years and their experience carries more weight with me. Talk to various machine shops who do these day in and day out and then make your decisions regarding custom machine work.
Boattailing the case and mooning the cylinders are other individual choices, but I did those as well. Maybe I wasted some money, maybe not. Although I have never seen a dyno sheet that showed a horsepower gain, I also have never seen any dyno sheets that prove that these are a waste of money either. Frankly, I don't believe that anyone has ever done a before/after test. Again, talk to various machine shops who work with these motors day in and day out and make your decision based on their responses.
It sounds like you will have a nicely done motor in the near future, show some pics as you move along!
Ralph
drums 02-04-2005 11:13 PM
Thanks Ralph,
Did you do a thread not too long ago about your 3.5? I followed that with interest. Is it still posted? I would like to review it. What was the threads' name?
Thanks for the encouragement,
Drums
asphaltgambler 02-05-2005 08:58 AM
Someone else here asked this question a while back. The 964 cams are very conservative IMO. The 20/21's are a good upgrade or better yet the SuperCup grind should work as far as passing emissions and increasing HP.
The one area in cam profiles that adveresly affect emissions quality is the overlap between the intake and exhaust 'hang-time' or lobe centerline. As you climb the ladder for more aggressive profiles the overlap starts to affect idle low speed driveability and of course emissions. The more agrressive profiles are designed to run at a higher rpm so there is a trade-off in efficiency at lower engine speeds.
The SuperCup grind is 1 degree tighter lobe seperation than the stock profile. Yes it does have more lift and duration but the action or ramp acceleration is much quicker as well. It should be no problem because you are also increasing total displacement .
John (Camgrinder) may chime in here, but I don't see any issue with emissions with either the 20/21's or the SuperCup grind in your build.
350HP930 02-05-2005 09:05 AM
Wow, I didn't know that the supercup would pass emissions in california.
Thats that grind I picked as a hot streetable cam for the 930.
drums 02-05-2005 09:37 AM
I have to stay with a tamed down version because of the emissions laws here in Ca. We have the most restrictive smog laws in the nation. The state is trying to force older cars off of the road. And I thought socialists only had the best interest of the poor in mind......
My main question on the 964 cams is what effect they will have on the engine configuration I have planned.
Drums
350HP930 02-05-2005 09:48 AM
The poor should take public transportation. Those of us with money for proper car maintenance and insurance would benefit from such a move.
asphaltgambler 02-05-2005 09:50 AM
I'm basing what I know here from the lift/duration/centerline specs on the stock SC vs 964 vs 20/21's vs SuperCup. I've spoken with John at length about my build and the most aggressive grind that was available to work with Motronic.
Looking at the specs for the SuperCup grind there should be no reason that a properly built engine shouldn't pass. The engine is just an air pump with the cam profile dictating at what rpm range it will operate efficiently.
The larger the total displacement; the less sensitive it will be to one particular cam profile. IE: 3.2 / Motronic with SuperCup about as aggressive as one could go. A 3.6 / Motronic could use a more agressive profile to achieve the same % increase in HP/TQ.
Jeff Alton 02-05-2005 10:52 AM
I am pretty sure John can grind the Super Cup cam with the 114 degree lobe center, but check with him. I believe he and I had talked about it.
Jeff
drums 02-05-2005 11:21 AM
The problem with a more aggresive cam profile in a smog repressive state such as California [this is coming to your state, too] is that they measure a few things beside hydrocarbons. If I am correct, the one [emission] that is adversly effected by an aggressive cam profile is what is reffered to as nox. High compression can be identified by a certain emission, too. Fellas, you have no idea [if you don't live in California] how difficult it is to make sure you don't cross the line. If my toe crosses any one of the states' lines, I get to take my engine apart and correct it. As stated in an earlier post, the owners manual [for an '89 3.2] states that the hydrocarbon measurement should be below 330. The state requires that number to be 120 or less, but out of the other side of their mouth state that my car has to meet original manufacturers' specs. Whichever of their rules is more stringent is the one that takes precedence. So yes, I am very paranoid because when the engine starts to wear, how close to the line I originally built it, it will be much closer, if not over that line in any one of many measurements.
Maybe we all will be taking government transportation someday.......
Drums
350HP930 02-05-2005 11:53 AM
If you are going with a programmable EFI you can come up with a barely streetable tune that will pass emissions and then switch back to a 'normal' tune when you pass tech.
drums 02-05-2005 12:05 PM
I am going to stay with the Motronic system and have '911Chips' [Steve Wong] make a couple of custom EPROMS.
Drums
Jeff Alton 02-05-2005 01:03 PM
Actually I do know, I live in a place that has testing at least as strict as yours! Steve can help you out. If the motor runs too lean the NOX goes up I believe. THere is a balance there that can be achieved with the motor you are planning. Lots of folks in California have done these mods before.
drums 02-05-2005 05:58 PM
Hi catca,
B.C.! Yes, you guys have it bad up there, too. B.C. was part of my territory in the mid eighties as a rep for a manufacturing company. Why does socialism concentrate on the coasts? It then eats its' way into the heartland.
Lets' enjoy our gas burners while we can!
Does anyone know what the carachteristics of 964 cams would be in my set up? Good low end, bad low end, mostly mid to upper power gains, a little better than stock all the way through the rpm range........?
Drums
Jeff Alton 02-05-2005 07:12 PM
I have a similair set up. Car has good low end, no worse than stock, and pulls a little better from around 3200 on up. If you go the twinplug route, I have a 964 distributor for sale!!
Cheers, Jeff
aigel 02-06-2005 12:22 AM
With all the money you are spending, why not sell your car and start with a smog excempt year that gives you complete freedom to put whatever you want in the engine compartment? If you like the later model looks, it's easy to put flares on a mid year car, say a 75 and end up with a mid 80s look.
I hope you are aware that you will not be smog legal, even if your pipe emissions are good. There is a visual inspection that will check things like timing, ignition etc. to be what that year engine calls for. It will take only one good smog tech to pick up on your mods and you will be in bad shape. I read on this board, that a guy tried to pass off a 3.0 for a 2.7 and got nailed, because the 2.7 has different advance than the 2.7, all other things looking practically the same.
I had to go to a smog only station, and reading this board, it looks like all 911s are now getting "profiled" and requested to go to a "smog only". No way you will be able to have a tech close an eye there.
Just a few thoughts. I like your engine build plans, but I'd rather see them coming from TX or AL. ;)
George
drums 02-06-2005 03:06 PM
test
drums 02-06-2005 03:17 PM
Hi George,
You are correct; the twin plug system will not pass a visual at the dreaded 'test only' station. The reason the 2.7/3.0 guy got nailed was because of the external vacuum advance was missing and it clued the technician in to the fact that things were not as they were supposed to be: stock.
The twin plug system would do the same thing. I will have to go back to the original plan, single plug with no modifications visible. The engine will run cleaner than my last 'test only', even with the modifications. Too bad the state has to be like this, the engine would burn even cleaner with the twin plug set up.
Hawaii has no smog laws.....
Thanks,
Drums
silverc4s 02-06-2005 04:14 PM
No place to drive in Hawaii.... Better move 2 TX!!
aigel 02-06-2005 04:15 PM
Originally posted by drums
Hi George,
I think the advance timing BTD is different at idle too. 5 on the SC and more on the 2.7. He basically would have to fake a 2.7 advance on the SC engine to make it pass.
We all agree, smog laws don't all make sense. I was looking forward to having my SC excempt, unfortunately that's never going to happen now. Time to move to NV and telecommute.
George
drums 02-06-2005 05:43 PM
Hey Bill, George,
I live too close to the ocean and Yosemite and Texas is flat with no windy roads........
Do any of you know how to strengthen an ignition system? I am going to upgrade the spark plug wires and am looking for a higher output coil. Know of a good, hot coil that will work with the Motronic system ['89 3.2/3.4]?
Thanks,
Drums
ChrisBennet 02-06-2005 05:47 PM
Hey Bill, George,
Thanks,
Drums
The Motronic ignition is very good in stock form and doesn't need any "help" from "upgraded" wires or hotter coils.
-Chris
aigel 02-06-2005 06:12 PM
What Chris said. As far as ignition upgrades go, many swear by the MSD boxes. I think they buy you most on a carbureted setup though and much of it in the bottom end and idle. If my ignition box would go out, i'd get an MSD, but I would not spend money on it if my stock ignition still works.
George
drums 02-06-2005 06:24 PM
Okay, I thought that sending a hotter spark might help in burning all of those nasty fuel molecules up. I am definately not going to swap out the Motronic system and have never considered it. Way back in the late 60s, in the VW club days, we used to put the Bosch Blue Coil in for a hotter spark. Didn't know if things like that were available for the Porsche.
Thanks,
Drums
aigel 02-06-2005 08:03 PM
I am no expert, so correct me if I am wrong: One reason for twin plugging is the fact that in a very flat and wide area (as in high compression and large bore) the flame front travels too slow, to ignite the entire mix in time. A hotter spark won't cure this, since that just ignites the mix, it does not increase the speed at which the flame front travels.
MSD can be beneficial, and it does not mean that you have to give up the motronic. Check here for more info: http://www.pelicanparts.com/techarticles/mult_MSD_install/mult_MSD_install.htm
Cheers, George
drums 02-06-2005 08:19 PM
Thanks George,
This will be a new direction of adventure for me! I followed the link you provided and will read it a few more times plus the section in Waynes' rebuild book on ignition systems.
The linked article mentioned only non smog 2 cars could legally use this type of system, but I am going to look further into that, too.
Drums
aigel 02-06-2005 09:04 PM
drums:
Yeah, there we go again. I didn't think about that at all... If the smog tech sees the MSD box, you will be in trouble. Any car guy recognizes them, since they are very common, especially on the US cars. Oh well. I guess there isn't much that you can do, without getting potentially in trouble!
Maybe it would be best to go with a 3.6 conversion, keeping the 3.6 specific smog and run it that way? That's completely legal and fairly straight forward. Yup, I think that will likely be the best way to go, without smog worries and without changing cars.
The other possibility is to keep a smog 3.2 around and build whatever you want to put in the car. At smog time, swap it back to stock. R&R the engine is about a full day's work at home if you have a bit of practise.
George
beepbeep 02-07-2005 05:39 AM
Yupp. Twin plugs ignite the mixture from two ends, so everything goes "bang" faster than with single plug. This in turn allows you to run more aggressive ignition timing as combustion pressure in cylinder will rise quicker and thus spend more time forcing the piston downwards.
With single plug, in-cylinder pressure will raise lazily, and your ignition curve would be more of a compromise where rapid gas expansion will fight the piston moving upwards for longer time than with dual plugs.
Ideal engine would have pressure peak raising infinately quick and ignition timing fixed @ 0 deg TDC, to maximize force on the pistion. In reality, flame front takes it's time and the bigger the combustion chamber is the lazier the "bang" is, forcing us to cheat and stage ignition so it comes roughly in time.
sorry for going off-topic ;)
drums 02-07-2005 05:43 AM
Hey George,
I think I am going to stick to original plan of going to 3.4 liters, 9.8:1 JE pistons in rebored and plated cylinders, 964 cams, bored and polished throttle body, extrude honed intakes, a Steve Wong chip and a header system that will come out every 2 years.
I have tried to do as much as I can without drawing too much attention at smog time and I think this is it.
Drums
ChrisBennet 02-07-2005 06:52 AM
Hey George,
Drums
With this setup the dual distributor and possibly the exhaust will be the only tip offs that you aren't stock. I wonder if you could run the single distributor on unleadsed race gas with a custom chip on inspection day?
-Chris
drums 02-07-2005 08:05 AM
Hello Chris,
I WAS considering a twin plug system but with the 'visual' the
smog tech does will automatically red tag my car. They won't
even run the smog test, they will just fail the car. There is an
arbitration process with a referee, but who wants to gamble
on that? New heads, labor, etc. No thanks, I'll just stick with the
single plug option and try to petition the California Air Resources Board to allow twin plugging because it burns so much cleaner on air and oil cooled engines [fat chance].
Drums
Jeff Alton 02-07-2005 10:31 AM
Drums, this may help ease your mind. I just took my car through emmissions testing one hour ago. The engine is a 3.2, 9.5:1, 964 cams, SSI(not cat) I put the stock chip back in for the test.
Here are the results:
Dyno (load) test
HC allow 227ppm measured 83ppm
CO allow 1.61% measured .71%
NOx allow 2334ppm measured 689ppm
Idle test
HC allow 380ppm measured 181ppm
CO allow 4.33% measured 1.08%
Not the cleanest engine around, but passed fairly easily!!
Hope this helps,
Jeff
drums 02-07-2005 12:45 PM
Hey Catca,
B.C. is pretty lenient! My max HC is 120 allowable. I wouldn't dare
show up with an ssi still installed!
How do those 964 cams work with the 3.2 [9.5:1]? Do you have any other enhancements like bored and polished throttle body, extrude honed intake manifolds, etc.?
Drums
Jeff Alton 02-07-2005 01:50 PM
The only other thing on the car is a custom SteveW chip. The cams are great. No loss of bottom end, but a stronger hit around 3200 all the way to redline. Couldn't justify the manifold work and I think the throttle body mod is like fluching cash down the toilet! The cams won't dramaticaly change the car. But, IF you are in there anyway, they are a nice upgrade. Just trying to figure out what cam I am going to use in the 3.6 now! If you have a cat, you will have no problems with the 964 cams when it comes testing time.
Jeff
drums 02-07-2005 05:23 PM
Hey Catca,
What do you mean by 3.6?
Drums
