JTL JTL is offline
JTL's Avatar
Cool 3.2 to 3.4 upgrade
The recent motor upgrade posts have sparked my interest. My -84 targa was recently repainted and so I need to start thinking about the next project. What's the best bang for the buck 3.2 upgrade? I have seen posts referring to upgrades all the way up to a 3.7 with a 10.5:1 3.4 being basically a piston swap; c2 cams are probably a good idea too?
What would the appx. parts cost for a 3.4 upgrade be? I noticed Pelican has the piston set for ~$840. What kind of price should I expect to get for the original parts assuming decent condition?
Then again I should probably leave this car for the street, get a roller and drop in a 3.6 varioram motor for a track/de beast.
jtl
Old 02-08-2005, 05:03 AM
Still Doin Time
asphaltgambler's Avatar
Most recent was Carrera 3.5's postings. Very detailed and well documented. Do a search. Lot's of builds done here with good results.
Old 02-08-2005, 05:17 AM
Irrationally exuberant
ChrisBennet's Avatar
A 3.2 to 3.4 upgrade involves changing from the stock 95mm P&C to 98mm - so you will need cylinders as well. If you want to run 10.5:1 you'll need to twin plug it. It's a fun project (BTDT) but not cost effective compared to a 3.6 swap.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-08-2005, 05:21 AM
Chris speaks the truth (as usual)... the additional thing that can be said about the upgrade vs. swap is that the upgraded/rebuilt engine is now 'fresh'.
There are folks (EBS for one) that will bore out your cylinders and replate them. I seem to rcall a $2k ish price for that work and new pistons.
figure a cam regrind $500+... valve work while you're in there $500+... twin plugging $??? et cetera
I suspect that this will be the route that I will go at some point if my 3.2 gets tired. I think the big question will be whether or not to twin plug since its going to be another couple thousand.... and then the PMO's for $3k... wait a second... thats starting to add up.
-Bernie
Old 02-08-2005, 05:42 AM
JTL JTL is offline
JTL's Avatar
I don't know if spending that kind of dough on street car, especially a targa, is wise. If you decide to do all that then you prolly wanna get the exhaust, suspension, brakes, cage etc. We are now talking about a track car?!
My plan B is starting to sound more appealing. Start with a widebody roller add a 3.6 motor and some other goodies. I know some guys on this list have done this. Would it be reasonable to assume this project could be done for ~$15-20k?
jtl
Old 02-08-2005, 06:54 AM
KobaltBlau's Avatar
Andy
Old 02-09-2005, 02:31 PM
