Cylinder group height's??
Not knowing cylinder's had group height's I purchased two used 2.0 biral cylinder's. It appears these are group height 6 where my four original are group 5. Can't determine any measured differences between the set's, so what exactly do the group height's mean and can I mix the 6's with the 5's?
I'm guessing the differences are incredibly small, but may cause a problem with even torque across the cam towers if the group's are not all the same. Are 5's and 6's close enough to not worry about?
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
Irrationally exuberant
I think 6's are higher than 5's. If so, I'd have the 6's machined to match the height of the 5's you already have. I wouldn't mix them as is.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Couldn't you just machine one 6 down to the size of the 5 and put then on one side of the engine? That'll save you a couple of bucks...
For your car (upto 1972) the height of the group 6 cilinders is 82.225 to 82.250 mm. The group 5 are exactly .225 mm lower (with the same deviation). I would take of .225 mm (almost a 1/100th of an inch) off from the bottom (surface that meets the crankcase) to prevent problems with the seal between the cilinder and the cilinder head. Or buy a third 'group 6 cilinder' and keep these on one side of the engine.
Try not, Do or Do not
Any good machine shop can match your mismatched set. If they machine all six, you can achieve a tolerance closer than factory spec. Oversided base gaskets can make up the difference for the material removed.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-14-2005 at 11:09 AM.. |
Thanks for the info everyone, I'm on the right track now.
