Difference in Cam Towers/Carrea 3.2 to SC 3.0
What's the difference in the Carrea 3.2 4 Bearing cam towers compared to the 3.0 SC Cam Towers? Are they better?
Irrationally exuberant
I think they are the same. I've got both kinds kicking around the shop so I can look if you need me to.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris,
Would you please check. I'm trying to purchase a set and I need to make sure they will fit on my 3.0 SC Case. Thanks. Scott |
Scott,
According to the PET, they have the same part number for the housing. I'm away from the shop this afternoon but I'll compare them side by side tomorrow. -Chris EDIT: If you have your old SC towers, the differences (if any) would be limited to things you can unscrew from your old cam towers and transfer to the Carrera ones.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 02-16-2005 at 01:17 PM.. |
Hey Chris,
My 3.0 is still in my car and I've got other plans for it. (VW BUS) I have been buying parts to build another 3.0/3.2 engine from scratch. So I can't check to see if they are the same or not. If you get the chance, in the next day or so, just take a look and I would really appreciate it. Thanks. Scott
Scott Tackett _______________ 1980 SC Targa (His) 1975 911S 25th Anniversary Edition (New addition to the family) 2003 VW Beetle Convertible (Hers) (I'm not going through midlife crisis, I'm just reliving my childhood obsession!) www.inhousenetworking.com/911/index.htm |
Does anybody else know if there is any difference? If somebody knows for sure, you can save Chris some time looking around in his shop.
Thanks.
I am pretty sure (98%) that they are the same.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Air Medal or two
are not some 3 bearing and others 2? seems like they inter change w.o. problems
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
The guy says that it is from a Carrea 3.2 and has four bearings and that these are more desirable than the three bearings. I'm building up a 3.0/3.2 and don't know the difference. First timer with the help from everybody on this BBS and Wayne's book.
Scott _____________ 1980 SC Targa (I'm not going through midlife crisis, just reliving my childhood obsession.) |
I checked this morning. The 3.0 cam towers I have have a different casting number than the 3.2 but I couldn't seen any differences. Unfortunately, the 3.0 cam towers I have were completely disassembled before I got them and I can't find the components/fittings.
I know I've run a much older (901 part #) cam tower in a 3.2 before so I'm pretty sure that the 3.0 and 3.2 are interchangable. -Chris
The 3.0 and 3.2 camshaft carriers both take the late style "4 bearing" cams. They will interchange.
Most 3.0 engines used the nut style cam and 3.2 used the bolt style. Both cams fit either housing.
John Dougherty Dougherty Racing Cams |
