Can piston squirters be disabled/enabled?
Some experts say the Nikasil cyls do not break in properly with piston squirters thus don't recommend them, so rather than removing them altogether as I would like to use them after breaking in, I wonder if a disabling/enabling switch can be connected to the circuit of piston squirters?
TIA |
Air Medal or two
I have never herd a expert say that.......mabe a wanabe expert??Anyway they are preasure acitvated so there is no way to turn them on and off.You want to break your eng.in on the loaded side so I see no other way to do it ,,the squirters are needed for cooling not oiling.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I also disagree with the opinion.
Irrationally exuberant
I would mentally "uncheck" the Expert box beside anyone who said that.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
