screwed up!
I stated in my post requesting 3.3 turbo rod bolt diameter information,that Wayne's book called out 10mm rod bolt diameter and doesn't specify turbo.( I just went to Appendix A assuming the info would be there) However, if I had read further in his book I would have found that he does address 3.3 tubo rod bolt diameter(9mm) on page 82!... In fact, he advises aftermarket replacement instead of OEM and explains why. (I received the same advice from the Porsche Tech thats helping me)....... learned another lesson...READ!
KM |
Friend of Warren
Ken, I must have read through Wayne's book 3 times before I actually started my rebuild. Still missed a few things though (like forgetting to transfer the starter ring from the old pressure plate to the new!)
Kurt V No more Porsches, but a revolving number of motorcycles. |
Oh wow, when did you figure out you didn't have a starter ring, when you hit the ignition key???
I'm going to hit the book one more time. Thanks! |
Friend of Warren
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Re: screwed up!
![]() -Wayne
