What to use for 8.1 commpresson on turbo Motor
I am in the process of rebuild the motor (top end)
it is currently 1984 3.2 turbo @9.5:1
what are my options to achieve 8.1:1 compression
Thank You
Williamknightperformance.com
Perfectpower.com
Old 02-23-2005, 07:03 AM
Still Doin Time
asphaltgambler's Avatar
If you have good ring seal you could install a different set of cams that would A) Be compatible with a street turbo set-up and B) Bleed off some of your existing cylinder pressure which will have the same effect as reducing the mechanical compression ratio.
PM John (Camgrinder) for advise
Old 02-23-2005, 08:01 AM
How about Mahle 98mm turbo pistons?
Perfectpower.com
Old 02-23-2005, 09:38 AM
Somewhere in the Midwest
MotoSook's Avatar
Tony,
I am having my cylinders bored and Nikasil plated to match 98 mm JE pistons. I'm not going to go as low in CR as you will, but I believe the JE pistons can be ordered with the CR you want.
I'm building a 3.4 Turbo.
Old 02-23-2005, 09:43 AM
I wanted to do what wydryd was interested in
Boring from 955mm to 98mm
Perfectpower.com
Old 02-23-2005, 10:12 AM
MotoSook's Avatar
If you mean by boring and replating..that's what I'm doing.
Old 02-23-2005, 10:33 AM
Forced Induction Junkie
WERK I's Avatar
Does anyone have a pic of a JE 98mm piston dome? I was wondering if they do custom compressions AND custom domes for those of us that have twin-plugged our engines.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-23-2005, 12:36 PM
Wo ist die Rennstrecke?
DonE's Avatar
I had JE make custom pistons for me. You can see a pic at:
http://www.brookstonefarms.com/930rebuild_page2.htm
I am building a motor that has a stroked (964) crank, super 964 cams, custom 98mm pistons and 3.2L cylinders bored out to 98mm (better cooling than the 3.3 cylinders and A LOT cheaper than Mahle).
The compression is 8.0:1 with very little dome on the pistons.
Old 02-23-2005, 04:47 PM
WERK I's Avatar
Thanks, Don
Dave
Old 02-23-2005, 05:36 PM
