Torch on a Mag case safe??
In the post below regarding removal of headstuds, heat seems to be the key. I have some studs that need removal in my mag case, but am reluctant to use my propane torch for fear of a magnesium flameshow in my garage. Is it really safe to put a torch to these things, or were those below referring to aluminum cases??
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
hell yeah! propane is pretty much worthless though. not hot enough. oxy/acetylene with a large, medium force flame and keep it moving. never lit one off yet.
up-fixing der car(ma)
Bill, I have your studs! I didn't forget about you. Please email me @ YTNUKLR@aol.com with your address. BUT, I only have 23 so you will need to heat up the case to pull one. The case is so large that it acts like a heatsink; all of it has to be at the temp of the propane torch to ignite... Mag ignites around 700* Fahrenheit, much hotter than an oxy/ace torch could get it...
ok, good info. I'll shoot you my address Scott, didn't want to keep bugging you all the time. I should be capable of removing one without screwing it up, so that should work good.
Bug me all ya like, I'd never do anything if it were up to me...
YTNUKLR,
You sound like my teenage son!
77 911, 3.0L |
I used a standard Sears torch with MAP gas. It took a couple of minutes -- but no issues.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Air Medal or two
propane and oxy are ,is a nice set up and dose most all things
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
