Torch on a Mag case safe??
In the post below regarding removal of headstuds, heat seems to be the key. I have some studs that need removal in my mag case, but am reluctant to use my propane torch for fear of a magnesium flameshow in my garage. Is it really safe to put a torch to these things, or were those below referring to aluminum cases??
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 02-23-2005, 04:44 PM
hell yeah! propane is pretty much worthless though. not hot enough. oxy/acetylene with a large, medium force flame and keep it moving. never lit one off yet.
206 637 4071
Old 02-23-2005, 06:17 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Bill, I have your studs! I didn't forget about you. Please email me @ YTNUKLR@aol.com with your address. BUT, I only have 23 so you will need to heat up the case to pull one. The case is so large that it acts like a heatsink; all of it has to be at the temp of the propane torch to ignite... Mag ignites around 700* Fahrenheit, much hotter than an oxy/ace torch could get it...
Old 02-23-2005, 07:29 PM
ok, good info. I'll shoot you my address Scott, didn't want to keep bugging you all the time. I should be capable of removing one without screwing it up, so that should work good.
Past:
Old 02-23-2005, 08:13 PM
YTNUKLR's Avatar
Bug me all ya like, I'd never do anything if it were up to me...
Old 02-23-2005, 08:20 PM
Doug Steinel's Avatar
YTNUKLR,
You sound like my teenage son!
77 911, 3.0L
Old 02-24-2005, 04:34 AM
jluetjen's Avatar
I used a standard Sears torch with MAP gas. It took a couple of minutes -- but no issues.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-24-2005, 04:44 AM
Air Medal or two
afterburn 549's Avatar
propane and oxy are ,is a nice set up and dose most all things
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-25-2005, 11:34 AM
