Cylinder Base Seal
Reading the engine rebuild book Wayne Recommends although not 100% necessary using the locktitie case sealant on the copper base gaskets. I have just opened up my gasket set and noticed that my base gaskets are not copper 100% as illustrated in the book they seem to be coated with a black finishing. Anyone else noticed this on the 3.2's and is it still possible/required/better to use the sealant with these gaskets?
Steve |
John Walker shared the good tip of spraying them with K&W Copper Coat.
Brian Keith Smith |
My kit came the same way yours did. I don't know what the black finish is, but I decided to lube them up with a little loctite 574 anyways. Just like Wayne says, can't hurt. It was a biaaatch getting the sealant on there though.
Good luck...
88 Carrera |
Try not, Do or Do not
We use Curil T on base gaskets because the cylinders move a great deal during the expansion that happens during normal running.
The Curil product is non hardening so it will move with the cylinder and continue to seal. It is certified for use in nuclear reactors so it also handles heat well. The 574 Loctite is an anaerobic sealant ( hardens in the absence of oxygen). When it hardens and is subsequently moved it cracks and no longer seals. There is the logic, you choose.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-19-2005 at 12:20 PM.. |
GAFB
I also used Curil T on the base gaskets and followed the same logic Henry did. This is one of the gasketing surfaces I'd be LEAST likely to use 574 on due to the movement of the parts...
Several BMWs |
What sort of product is Curil T? I dont think I have ever seen that for sale in the UK, Will RTV silicone work the same or is it a different product?
Thanks Steve Richards |
GAFB
Curil-T is a non-hardening gasket dope and is not the same as an RTV silicone. Under no circumstances would I use RTV silicone on a cylinder base gasket.
Pelican's got Curil-T. I haven't seen a product of similar characteristics and quality on the shelves at any FLAPS around here, but you may have better luck.
Several BMWs |
Curil T is an Elring product made in Germany.
I believe that a RollsRoyse product called Hylomar (sp?) is basically the same. We offer Curil T on our website if our host does not offer it.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Hylomar is also availabel from Permatex. I have used both it and curil T without any problems.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Doesn't want/need a 3.6L
I use Permatex High-Tack sealant, which is also what Andial & Porsche Motorsport use. Works fine for me (and them).
Every engine builder has their favorites. There are many ways to skin a cat. Ralph |
Another vote for Copper Coat.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
