1972_911T's Avatar
Cylinder Base Seal
Reading the engine rebuild book Wayne Recommends although not 100% necessary using the locktitie case sealant on the copper base gaskets. I have just opened up my gasket set and noticed that my base gaskets are not copper 100% as illustrated in the book they seem to be coated with a black finishing. Anyone else noticed this on the 3.2's and is it still possible/required/better to use the sealant with these gaskets?
Old 10-18-2005, 10:41 AM
John Walker shared the good tip of spraying them with K&W Copper Coat.
Brian Keith Smith
Old 10-18-2005, 11:21 AM
My kit came the same way yours did. I don't know what the black finish is, but I decided to lube them up with a little loctite 574 anyways. Just like Wayne says, can't hurt. It was a biaaatch getting the sealant on there though.
Good luck...
88 Carrera
Old 10-18-2005, 12:51 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We use Curil T on base gaskets because the cylinders move a great deal during the expansion that happens during normal running.
The Curil product is non hardening so it will move with the cylinder and continue to seal. It is certified for use in nuclear reactors so it also handles heat well.
The 574 Loctite is an anaerobic sealant ( hardens in the absence of oxygen). When it hardens and is subsequently moved it cracks and no longer seals.
There is the logic, you choose.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-19-2005, 12:17 PM
dtw dtw is offline
GAFB
I also used Curil T on the base gaskets and followed the same logic Henry did. This is one of the gasketing surfaces I'd be LEAST likely to use 574 on due to the movement of the parts...
Several BMWs
Old 10-19-2005, 12:50 PM
1972_911T's Avatar
What sort of product is Curil T? I dont think I have ever seen that for sale in the UK, Will RTV silicone work the same or is it a different product?
Thanks Steve Richards
Old 10-19-2005, 12:57 PM
dtw dtw is offline
GAFB
Curil-T is a non-hardening gasket dope and is not the same as an RTV silicone. Under no circumstances would I use RTV silicone on a cylinder base gasket.
Pelican's got Curil-T. I haven't seen a product of similar characteristics and quality on the shelves at any FLAPS around here, but you may have better luck.
Several BMWs
Old 10-19-2005, 01:11 PM
Curil T is an Elring product made in Germany.
I believe that a RollsRoyse product called Hylomar (sp?) is basically the same.
We offer Curil T on our website if our host does not offer it.
Henry Schmidt
Ph: 760-728-3062
Old 10-19-2005, 02:04 PM
Jeff Alton's Avatar
Hylomar is also availabel from Permatex. I have used both it and curil T without any problems.
Cheers
www.turn3autosport.com
Old 10-19-2005, 05:25 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
I use Permatex High-Tack sealant, which is also what Andial & Porsche Motorsport use. Works fine for me (and them).
Every engine builder has their favorites. There are many ways to skin a cat.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 10-19-2005, 08:28 PM
David's Avatar
Another vote for Copper Coat.
Old 10-19-2005, 10:06 PM
