rotorhead's Avatar
Look at my cylinder wall
Dismantalling my 3.3 I noticed a mark on the wall of cylinder #5. The mark is smooth and shiny. The cylinder is a low milage Nikasil.
Any ideas what may have caused this? and do I need a new cylinder or will this hone out?
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 03-06-2005, 04:07 AM
Irrationally exuberant
ChrisBennet's Avatar
If you can't feel it with your fingernail ("smooth and shiny") you're fine.
In the picture it looks like a line drawn with a permanent marker.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-06-2005, 05:42 AM
I would rather be driving
jpnovak's Avatar
Permanant marker (Sharpie) will easily come off with acetone or alcohol, not the kind found in bottles and cans.
Old 03-06-2005, 05:56 AM
Licensed User
Shuie's Avatar
Sharpie
Was that there when you disassembled the motor? Are the other cylinders marked 2-6?
Old 03-06-2005, 06:32 AM
Forced Induction Junkie
WERK I's Avatar
It looks very close to the area of your top compression ring. I suggest pulling the piston and inspecting the ring for a shiney spot. It may have been a defect on the gap portion of the ring that caused the polished line on the cylinder. Is it a black line or the end result of something rubbing hard enough to wear the cross hatch pattern down and leaving a very smooth relective surface?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-06-2005, 08:22 AM
rotorhead's Avatar
It looks like a black line in the photograph but is really a mirror smooth part of the cylinder wall. I agree that it appears to run close to the top of the cylinder and that its track would be very close to that of the top ring. Can't feel it with a finger nail.
I have a new set of geotze rings to go in so I'll pull the piston out and inspect the rings. It is odd that it has a slight yet well defined "squiggle" to it. The valves look ok, I can't see any eveidence of a foreign object.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-06-2005, 12:45 PM
