OldTee's Avatar
Post Alusil options?
OK, what are the options (other than $2400 new cyls and pistons)? 140000 mile motor, cheap top 25000 miles ago, burns (not leaks) about 1 qt in 400-600 miles, 96% all six. Engine on stand and about to be cleaned up with new airbox and CIS inspection, SSI install on a 3.0 79SC currently in the paint shop.
The bottomline? Re-ringing Alusil is a crapshoot - it may or may not work. Walt's suggestion is what he has learned from past experience...
From Wayne
Old Tee
all 911s sold
Old 03-06-2005, 05:42 AM
OldTee's Avatar
PS I read your book. Hoping something has changed! Grim.
Old Tee
all 911s sold
Old 03-06-2005, 07:26 AM
David's Avatar
I'd either keep the old rings or send out the cylinders for coating and buy new pistons.
Old 03-06-2005, 08:23 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
John,
JE pistons and Nikasil coating the cylinders is another option, about $1800 through EBS.
There is also a local shop here in Falls Church that has the correct Sunnen machine and paste to 'recondition' your Alucil C's. Just make sure P/C's are in spec before.
Send me a PM and I can get you their info.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 03-07-2005, 11:41 AM
KobaltBlau's Avatar
Re-ring Alusils?
Andy
Old 03-07-2005, 12:09 PM
OldTee's Avatar
An ending worth sending? I pulled the CIS and exhaust and took a good look at the engine. Did a leak down. Results were 96 to 98%. Cylinder walls showed no cross trama. Valves guides installed 10000 miles ago without new valves showed some oil leaking. No major leaks around cylinders so... I decided to put her back in the car and run her until she gets sick. She is a 140,000 mile engine, is in typical shape for her age, and like any other old girl has some good miles left in her before Botox!!!
Old Tee
all 911s sold
Old 03-13-2005, 05:29 AM
3 restos WIP = psycho
kenikh's Avatar
Originally posted by KobaltBlau
Re-ring Alusils?
Read the WHOLE THREAD. It's worth it.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-13-2005, 09:21 PM
