scored cylinder
I need a new cylinder,.. can't find one.. can I have the cylinder cleaned up and Nikasil coated back to spec? Or do I need to have all 6 bored and replated and go with new oversize pistons? Can someone recommend a place that can rework and re-plate?... maybe Dallas/Ft. Worth area?
thanks
Km
Old 03-07-2005, 06:41 PM
Irrationally exuberant
ChrisBennet's Avatar
And the motor would be....
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-07-2005, 08:37 PM
You can get the cylinder re plated if it is not real bad. Give Stephen Kaspar an email...he did my cylinders not to long ago. You can be sure it will be done right! His email is porschephd@imagineauto.com tell him I sent you.
Eric Hood
Old 03-07-2005, 08:47 PM
He is in Kansas City
Thanks Eric, I sent him some pictures
KM
Old 03-08-2005, 08:24 AM
Chris, its a '78 3.3 turbo.
Old 03-08-2005, 08:45 AM
On an SC, the sealing ring groove at the top of the cylinder makes them unsuitable for boring out. I wonder if 3.3 cylinders have the same limitation.
-Chris
Old 03-08-2005, 08:56 AM
Hummm.. don't know! Are you talking about the groove for the copper gasket that mounts to the case?
Old 03-08-2005, 11:03 AM
I mean the groove in the top of the cylinder that holds a sealing ring. The sealing ring was Porsche's way of better sealing the cylinder to head.
-Chris
Old 03-08-2005, 11:39 AM
no grove in these
Old 03-08-2005, 09:12 PM
Bad news from Imagine.. looks like I need to replace? Does anyone know where I can get a 97mm height group 5?
KM
Old 03-09-2005, 08:25 AM
