Break in day 2, runs great above idle
Day #2 break in
(What’s the use) 1. Car runs like a small jet at RPMs above 2000, but 2. Stalls at idle How far out should the idle mixture screws be out on Zenith/Webbers. Haynes says 2 1/2 turns. Should I go there? Thanks so far I'm very
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
2 1/2 is just the starting point. you also need 0.55 idle jets. there are a lot of 0.45 and 0.50 jets still in use and they just don't work well with today's gas. get it hot, set the idle speed at about 1200, turn one screw in until you hear the idle speed drop a bit and then turn it out just to the point it recovers well and idles the fastest. then do the next one. when you've done all six, hopefully the idle will be better and not want to die. drop the speed to 1100 and go around once or twice more. if you close your eyes and tune in to the sound of the engine while you do the adjustments, it's easier to hear minute changes in RPM.
the timing must be adjusted properly before you do the carb adjustments, or it's a waste of time.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-25-2005 at 05:51 PM.. |
OK, thanks, I've copied your information and will do the six screws (trying not to breathe too much).
the car is idling right at 980-990. Perfect driving at the higher RPMs. No pinging and no backfiring, and no smell of fuel. Thanks!!!!
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche Last edited by H.G.P.; 03-26-2005 at 04:46 PM.. |
