Oil Pressure/Cam Restrictors
Oil pressure on freshly built 2.4 with all oil system upgrades including Cam oil restrictors is over 115 psi @ 5000 , 25 psi at idle 65 C oil temp. Cold oil temps (20C) are higher 38 psi at idle for example.
Pressure is correct measured with calibrated mech. gauge, both relief pistons verifed and not sticking.
I am now thinking of pulling the cam oil restrictors as I feel the
pressures are excessive.
Any comments ?
Chris
Old 03-22-2005, 08:01 PM
I took mine out for the same reasons.
-Andy
Old 03-23-2005, 12:33 PM
vichang4's Avatar
How about just drilling out the restrictors to make them a little larger. My 930 runs over 5 bars @ 5000 rpms, but right at 2 bars at idle with the updated restrictors.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 03-23-2005, 02:07 PM
"Oil pressure on freshly built 2.4 with all oil system upgrades including Cam oil restrictors is over 115 psi @ 5000 , 25 psi at idle 65 C oil temp. Cold oil temps (20C) are higher 38 psi at idle for example.
Pressure is correct measured with calibrated mech. gauge, both relief pistons verifed and not sticking."
Your idle pressures seem okay, but your normally operating pressures are high. If you made that observation, why do you say the "pressure is correct...."?
Do you think the previous factory camshaft oil restrictors (larger orifice) will reduce the oil pressure by 50 psi or so? I think you should look at the pressure relief system for a solution.
MHO,
Sherwood
Old 03-23-2005, 06:46 PM
My statement "pressure correct" refers to the fact that the pressures indicated on the gauge are correct and that the gauge has been calibrated. By calibrating the gauge and verifying that what it reads is correct I can then be sure it is actually reflecting oil pressure and not a sender problem, ground problem etc.
With respect to the relief system, bypass mod done, new relief springs and pistons added. Pistons were removed to check for binding and smooth travel in the bores with no problems found. Relief spring for the horz. oil pressure relief requires slightly more pressure to compress then the old spring removed but this is a new spring vs an old spring.
Chris
Old 03-24-2005, 04:23 AM
"Relief spring for the horz. oil pressure relief requires slightly more pressure to compress then the old spring removed but this is a new spring vs an old spring."
Pressure gauge calibration understood. Thanks.
If the new spring exhibits more tension than the old spring, that implies a higher relief pressure threshold. Perhaps substitute the old spring and see what happens.
Sherwood
Old 03-24-2005, 10:31 AM
