Air Medal or two
RSR rocker seals.....
I recieved these from our host today......they are flat rubber washers sort of..can some one steer me as how they are installed??????just put them on the ends???
I thought maybe they would be "O" rings that go over the shafts some how.......but anyway need direction here Thanks!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Just slide them over the end carefully, they can tear. Once they are on and in the groves the design will look normal. When I got mine the first time, I thought they looked a little strange too.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Irrationally exuberant
Just put the on the ends and slide them on until the fall into the groove. I don't know if it makes a difference but I try to make sure they don't "roll over" and get inside out when I install them.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Air Medal or two
Ok!! thanks dudes......the grooves.....its been awhile seince apart....all coming back to me now..Thanks!!
