Replacing through bolt seal
Hi all,
I've strip my 3.6 engine down to the short block. Now, I want to replace the through bolt seals that are leaking. My question is that, can I remove the through bolt completely to replace the seal on both the nut and bolt sides? I want to do this one through bolt at a time, replacing the seals on both sides, then torque the bolt back to spec and move onto the next one.
Does this sound okay?
thanks,
anthony
Old 03-21-2005, 08:39 AM
you can do that. use the tough green seals. don't even bother with the wimpy blue ones.
206 637 4071
Old 03-21-2005, 08:46 AM
Irrationally exuberant
ChrisBennet's Avatar
Check out this recent thread First time rebuilder gaining momentum! for info on replacing the through bolt O-rings.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-21-2005, 09:36 AM
Absolutely push the gasket over the threads onto the larger shaft portion of the case bolt, otherwise the threads will chew up the o-ring like a tasty lunch!
I wonder if you should do them in the same order as the tightening sequence...? I can't hurt.
Old 03-21-2005, 10:12 AM
Thanks for the info. My main concern was that if pull the through bolt out, BAD stuffs will happen.
---anthony
Old 03-21-2005, 11:52 AM
Make sure you get old O-rings out. When you pull the thru bolt out, the O-ring closest to the end may come off inside the motor. It wouldn't hurt to run a plastic gun cleaning brush or a long handled bottle brush through the thru bolt passage to clean it out.
-Chris
Old 03-21-2005, 03:08 PM
for an installation sleeve, to protect the o-ring from the threads, i went to a hobby shop and found a thin brass tube that just fit over the threads, and cut off a couple of inches with a tubing cutter. the tubing cutter rounds the end of the tube in the process, which makes it easy for the o-ring to slip over.
206 637 4071
Old 03-21-2005, 03:25 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
I put tape over the threads and then ran the O-ring over the tape.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 03-22-2005, 05:26 AM
