Air Medal or two
afterburn 549's Avatar
RSR rocker seals.....
I recieved these from our host today......they are flat rubber washers sort of..can some one steer me as how they are installed??????just put them on the ends???
I thought maybe they would be "O" rings that go over the shafts some how.......but anyway need direction here
Thanks!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-23-2005, 09:25 PM
Jeff Alton's Avatar
Just slide them over the end carefully, they can tear. Once they are on and in the groves the design will look normal. When I got mine the first time, I thought they looked a little strange too.
Jeff
www.turn3autosport.com
Old 03-23-2005, 10:30 PM
Irrationally exuberant
ChrisBennet's Avatar
Just put the on the ends and slide them on until the fall into the groove. I don't know if it makes a difference but I try to make sure they don't "roll over" and get inside out when I install them.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-24-2005, 10:21 AM
Air Medal or two
Ok!! thanks dudes......the grooves.....its been awhile seince apart....all coming back to me now..Thanks!!
Old 03-24-2005, 04:13 PM
