She's going back together
Well, after last years racing 'incident' I can finally see light at the end of the tunnel on the engine rebuild. Hopefully back in the car in the next week or two.
Here's some obligatory pics.
New, ceramic coated 10.5:1 pistons
Timing the GE-80 cams
MFI pump
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 03-12-2005, 01:13 PM
stevepaa's Avatar
Where does one get pistons coated, and is that anything like the old flame impingement carbon coating?
steve
old rocket inguneer
Old 03-12-2005, 01:28 PM
Ryan
Looking good . I am very impressed at the speed that you have managed to get it rebuilt. I think I need to get lessons from you - last commitment made to me was that motor and box would be in the car by this weekend and I would be able to drive down to Gouldburn next Sunday. Judging by the lack of progress by Friday it does not look very hopefull. Are you going to run at Gouldburn if the car is running in time or will you spend some time running the motor in properly?
Robert
Old 03-12-2005, 03:57 PM
hey rob
i think the speed is due to my spending my last umpteen saturdays in the shop doing all the non-critical tasks i.e. disassembly, hours and hours of cleaning and reassembly of the ancillaries.
your motor looked 90% down (to me) - and the 914 looks great. what are you doing for induction? howard has been told mfi is allowable in a 914 for targa, adelaide etc...
steve - we're in australia so our contacts are unlikely to help. the pistons have an oil shedding coating on the underside to aid cooling (as does my case interior) and a protective coating on the top. a google search should find heaps of places that do it in the US.
Cheers, Ryan
Old 03-12-2005, 10:47 PM
ps. i prob won't do the wakefield round - i want to do some normal running in before i compete in the car
Cheers, Ryan
Old 03-12-2005, 10:48 PM
/Quote
Quote/
WTF???
Too bad you won't be at Wakefield...
Another 914???
Cheers,
Mark L.
Old 03-12-2005, 10:58 PM
Ryan
Going with Webers - would never have thought that MFI would be allowed for Targa Tas e.tc. - seems to be completely inconsistent. Think its crazy for example that we cant use an early alu crankcase but a 74 RS3.0 can use a 9 bolt crank in an SC case - go figure?
Robert
Old 03-13-2005, 12:56 AM
mark/rob
i think the problem stems from rules having to cover so many different types of cars, most of which are not as 'interchangeable' as porsches. so when you apply the rules to porsches you get some strange results.
and it only get worse when you try and build a car for more than one type of competition...
Cheers, Ryan
Old 03-13-2005, 02:18 AM
Doug Steinel's Avatar
Obrut, Is this beast twin plug?
77 911, 3.0L
Old 03-13-2005, 05:01 AM
doug,
the heads are drilled for twin plug - but the distr is still on the 'to do' list.
it runs fine with single plug on our premium fuel
Cheers, Ryan
Old 03-13-2005, 01:56 PM
350HP930's Avatar
Depending on the heat conductivity of the oil repelling coating it may do more harm than good on the bottom of a piston.
One must not forget that aluminum is one of the best heat conductors there is.
I have also heard that some people have had problems with ceramic piston dome coatings chipping and peeling off.
I hope neither is the case but I just thought I would pass along the info that kept me from applying any types of coatings to my pistons.
Old 03-13-2005, 02:30 PM
350
we had similar coatings on the pistons i previously used - ran them for 2 seasons and they were perfect when we pulled them out.
Cheers, Ryan
Old 03-13-2005, 03:12 PM
Who did your ceramic coating on the crowns? Did you also do the skirts and ring lands?
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Charles Navarro
President, LN Engineering and Bilt Racing Service
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-13-2005, 06:59 PM
charles
coating was by hpc - http://www.hpcoatings.com.au/
black stuff on the undersides and skirts - light grey stuff on the crowns. i don't know much more about it as my mech spec'd it.
Cheers, Ryan
Old 03-13-2005, 07:23 PM
drag racing the short bus
dd74's Avatar
Bump - out of interest.
The Terror of Tiny Town
Old 03-14-2005, 02:14 AM
Yup, that's some nice work that HP Coatings does over there! Did you by chance also opt for doing the combustion chambers and the exhaust ports? Did they give you any figures on how much more power or what kind of oil temperature reduction was to be expected? We've had some really good results with that combination ourselves with the coatings done by Calico Coatings (USA).
Charles Navarro
LN Engineering
Charles Navarro
Old 03-14-2005, 05:35 AM
"Did you by chance also opt for doing the combustion chambers and the exhaust ports? "
nope
"Did they give you any figures on how much more power or what kind of oil temperature reduction was to be expected?"
some, in both cases
Cheers, Ryan
Old 03-14-2005, 01:58 PM
made some more progress today - its starting to look like an engine.
however, the 2nd tensioner was a bit iffy - so we decided to order a replacement and down tools.
here's some pics:
Cheers, Ryan
Old 03-18-2005, 10:38 PM
Langers's Avatar
Looking good!
2004 VW R32 - B road bahnstormer
1992 Peugeot 205 - Tarmac rally weapon (well eventually...)
Old 03-19-2005, 07:08 PM
engine is done, in the car and running!! i did a quick test drive around the block yesterday afternoon - will try and post some pics tonite.
it feels/sounds great.
Cheers, Ryan
Old 03-28-2005, 04:31 PM
