2.4 jetting Weber carbs
Hi
I have built a new engine to my car. It started as a 2.4T -72 engine. I need help with jetting my Webers to the new spec. Carbs are set up with 110, 50, 145, f1 and 30mm venturios. Spec is now... E-cams 2.4S pistons Ported heads 37mm/Intake and 36mm/Exhaust 40mm Webers.. Sportmuffler Thanks Henrik SWEDEN |
Here are some examples with mixed results.
http://forums.pelicanparts.com/uploa...1112020142.jpg It looks like Zendalar has gone there before you. You might want to check with him regarding where he ended up. In addition Cegerer's got a 2.5 with solex cams. His runs fine, but slightly rich and is jetted as follows. Venturi: 34 Main: 140 Air Correction: 180 Idle: 55 Emulsion tube: F26 |
My car (73 2.4T CIS conversion) is equipped with 130 main, 55 idle, 180 air cor., F1 emulsion tubes and 30 mm venturis. A bit on the rich side but runs great and reliable on the street and on the track.
Here is a link to to a post I made something ago showing the effects of jetting changes on a 2.4E motor w/40mm webers.
http://forums.pelicanparts.com/showthread.php?s=&threadid=209700&highlight=40mm+w eb+jetting The emulsion tubes will have an effect on the jetting. The most common e-tubes seem to be the F3 & F24. |
| All times are GMT -8. The time now is 05:52 PM. |
