Irrationally exuberant
ChrisBennet's Avatar
Grrr, rocker arm rebush clearance question
I'm inspecting some rebushed & reground rocker arms and the shaft to bushing fit is the same as ones with 100K+ miles. It's not really loose, just not as snug as a new rocker arm. How critical is the fit? I don't have a way to (personally) measure the bushing's I.D. so I can't give you actual numbers.
I'm I pissed for no reason?
BTW: These rockers were not done by C.E.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-30-2005, 05:55 AM
camgrinder's Avatar
You can buy an inexpensive telescoping gauge to measure the I.D. of the bushing. Then measure your rocker shaft O.D. and get the clearance.
http://www1.mscdirect.com/CGI/NNSRIT?PARTPG=NNLMK3&PMPXNO=1756643
John Dougherty
Dougherty Racing Cams
Old 03-30-2005, 09:05 AM
Yeah, I need to get some snap gages. My bore gage doesn't go that small.
-Chris
Old 03-30-2005, 08:27 PM
Jeff Alton's Avatar
What is the deal with snap guages? Take a measurement and then use a micrometer to get number??
Jeff
www.turn3autosport.com
Old 03-30-2005, 10:57 PM
Hald's Avatar
Once you are able to measure the bore & know the clearance between rocker & shaft, do you have a spec to know whether you're within tolerance?
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 03-31-2005, 04:47 AM
Chris,
Please don't tell me those rocker arms came from RAS. I had mine done there after your earlier comments.
Jack
Old 03-31-2005, 05:07 AM
Originally posted by 75-911S
Chris,
Jack
OK, I won't
This was the first time I'd tried this vendor. What sucks is that I told my friend/client about this place so he sent his rockers there before giving them to me to use in his motor.
Here's the thread that sent you down the path.
cams and rockers
-Chris
Old 03-31-2005, 05:44 AM
Ugh. too late now.
How about the Atlantic Enterprises people for head work, etc.? Are they okay?
Jack
Old 03-31-2005, 06:05 AM
Ugh. too late now.
Jack
YES! They're the greatest.
-Chris
Old 03-31-2005, 06:08 AM
