LinkBack | Thread Tools |
I need two new Rocker Arms, Why do I have to have the Cam and Rockers Re-ground?
It doesn't make sense to me but can anyone help. I have two broken rockers on the right side cam, an intake and exhaust were broken, why do I have to perform work (grinding) on new rockers and the cam? I magnufluxed the cam and it had no cracks so what's the big deal? Your comments are greatly appreciated.
Best Regards, Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
PRO Motorsports
If you know how to inspect rockers and lobes, then you may not have to.
If you have decent lobes, and a good pair of used replacement rockers, then you can install them and check their mesh with one another with some Prussian Blue to make sure that they are square. Otherwise, there may be high pressure points that will wear rapidly and the surface hardening will chip off from the heat and stress.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Tyson,
I see, this I can do and will check for. I have the necessary materials to do the job. I already checked out the cams and there is no damage to the lobes or cracks. Thank you for your time! Best Regards, Alex
Author of "101 Projects"
In general, the parts wear with each other. Putting in new rockers with old cams is like giving yourself a new set of lower teeth in your mouth. You'll have wear points at the high points where they meet - not really a good thing.
However, you can sometimes get away with it if your camshaft is not worn too much... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
A nice surprise to hear from you Wayne, thank you for your feedback and great job with Pelican Parts!
Best Regards, Alex
I lurk often, although I've been super-busy here lately...
-Wayne
I'm here to cause trouble
Wayne - great analogy with the teeth. I take it you are speaking from a bad dental experience? :-)
Alex- you might consider taking all the rockers out and putting RSR seals on the shafts and checking the condition of the other rockers. JB |
..duplicate removed...
I have all my rockers out and have already bought my entire rebuild kit from Pelican, including the RSR seals. I plan to check the rockers out as well. Any suggestions on who can recondition my rockers in Northern California, or is it really needed if everything looks well?
