Cool Intake Manifold Gasket
I am in process of putting intake manifold back on block on a 70 911T with Zenith Carbs.
I can't find information about using gasket sealer for the gaskets (intake manifold to head and carburetor to intake manifold).
Previous owner used sealer on both ??.
Any thoughts ?
Based on prior experience I am inclined to install both sets of gaskets dry on cleaned surfaces.
Jon
Old 05-05-2005, 08:50 AM
Nitrometano's Avatar
The sealer that I use for that gasket is a marine type. Is use for outboard marine engines. I dont remember right now the name. Looks like Shellac but not are the same. Is better. The small white can with blue letters says: gasket maker. The color is like dark purple. I found it at Pep Boys.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 05-26-2005, 08:02 PM
Banned
snowman's Avatar
Green gaskets should be used dry.
Old 05-27-2005, 11:54 AM
