Banned
Banned
The followin has been lifted from a repair manuel for a very late model engine. The info is typical of the entire industry for late model engines. Black, blue, green, even pink felt tip markers can be used instead of blue dye.
Thanks for posting this Jack - it all sounds like useful stuff, but why does it say that you can lap refaced valves but should never lap new valves "under any condition"? Is there something about the surface of new valves which would damage the seat if you tried to lap them?
Charles '84 911 3.2 Last edited by CharlesJones; 05-19-2005 at 04:03 PM.. |
Banned
What I have read is that there is some kind of special coating on the face of new valves. Other thing I have heard is that new valves are so perfact and concentric that the only thing you can do to them is to make them worse.
Jack,
That all make sence now ........ I was missing the bit about the ridge above and below the contact area after AGRESSIVE lapping. I am just about to tear into my engine and in a cost saving effort my first though was to lap the valves to make sure I had a good seal. I now think that I should have them cut. OK the price of the rebuild has just gone up. Thanks for the good information!...........Cheers |
Banned
An additonal note for those taking notes. THe specs for the angles, margins, and seat widths given are for valves that are approx 1" dia to 1.3" dia and for a particular engine. Do not use these specs for your engine, use your manufacturers specs for your year and model.
