adamb113's Avatar
stripped head exhaust studs
I have a 2.4L Some of the exhaust manidfold stud holes in the heads are begining to strip. What is the prefered method of repair without pulling the motor?
Timesert
Helicoil
Stepstud
Where is the best place to get a kit for the prefered method?
Thanks,
Adam
1973 911 T Targa
Old 05-21-2005, 12:24 PM
Irrationally exuberant
ChrisBennet's Avatar
Time-Serts work well in that application. Belmetric in Tyngsboro sell the kit$ and the inserts.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-21-2005, 01:16 PM
adamb113's Avatar
Thanks Chris!
Will they know what size I need? depth etc?
What happened at Limerock? Big Bend?
I love that track!
1973 911 T Targa
Old 05-23-2005, 05:20 AM
Hi Adam,
The "normal" size TimeSert should work. The stud sticks into the head 17mm and the "normal" TimeSert measures 11.6mm long. There is a longer TimeSert (almost 17mm long) but I would be afraid that the hole wouldn't be deep enough to accomodate the drill and tap for that insert.
If you don't mind coming up to Nashua NH I'll lend you my kit. (The kits are quite expensive.)
-Chris
Old 05-23-2005, 12:09 PM
adamb113's Avatar
Chris,
I live in Danvers, MA so it would be no problem to swing up there. I appreciate the offer. What else will I need to purchase to compliment your kit?
Adam
1973 911 T Targa
Old 05-23-2005, 12:16 PM
