oil bypass mod.
hi pelican parts
I've checked today the Factory technical bulletin tha's been given to Porsche dealers many years ago, about oil bypass mod.
the hole to drill is 3mm diameter according to Porsche specifications.
It seems to be small compared with the pics i've seen on this board....
What do you think about that ?
Many thanks
Philippe
Old 05-23-2005, 04:08 AM
bump
Old 05-24-2005, 12:29 AM
Phillipe
Look at Oil bypass modification
Just get the equiv metric plug (6mm) and a tap for it, Use a dremel to grind the start, then drill with a pistol drill, To tap for the plug you have to shorten the tap and grind some flat on it
HTH
Neven
Old 05-24-2005, 01:23 AM
Hi NevenM
i've checked your thread
shall i really drill 12mm diameter ?
the factory bulletin i have says 3 mm
what does "tap" mean
Philippe
Old 05-24-2005, 05:36 AM
Home of the Whopper
I can't remember what size I used, but 12mm sounds a little big. That's almost 1/2"!! 6mm sounds closer, but I can't remember.
Tap means to install threads so you can screw in a pipe plug.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-24-2005, 09:58 AM
3 restos WIP = psycho
kenikh's Avatar
It means you need one of these:
mytoolstore.com/wilmar/prod042
I have never used this company; just stole their picture.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-24-2005, 10:33 AM
Philippe
Drill the bypass hole about the same diameter as the hole you block , about 6mm. If you are not sure take the case to a machinist with some pictures of it and say block this hole and drill one thru to here. I started with a 3mm drill and then fept increasing until I got to 6mm
HTH
Neven
Old 05-24-2005, 12:55 PM
many thanks
these are good informations, as always
best regards
Philippe
Old 05-25-2005, 01:16 AM
