Pressure fed tensioner saftey stops
Hi all I just modified my pressure fed tensioners with a tube under
the piston to stop it from collapsing completely if it fails. Has anybody else done this I got the how to info from EBS I made a 7 mm tube to fit in there. My chains seem tight now tho not as tight as when I adj cam timing I can move the chains up and down about a 1/2" where they go over the ramps and the engine
turns over easily not tight like when you adj cams. I still have about 15mm of travel left in the tensioners.My question is is how tight is to tight my chains are new how much do they stretch?
thanks Palmer
Old 06-17-2005, 09:09 AM
