BReyes's Avatar
Engine is in: Ready to start after rebuild, but only get click, click, charging more
Engine is in: Ready to start after rebuild, but only get click, click, battery charging more (2 amps overnight). Could it be something else causing the engine not to spin over.
Will try again in morning. The starter is nearly new.
Thank You.
Regards,
Bernard
Old 06-15-2005, 08:57 PM
Air Medal or two
afterburn 549's Avatar
how old is the batt? double ckec all connections no cheating all the grounds too..last resort cross the syl. and see if that works
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-15-2005, 09:58 PM
BReyes's Avatar
Bat was good. I charged it yesterday afternoon (some fast and few hours slow). The windows and lights work, so...
It goes click when turn key.
Newer Sachs clutch.
Newer Bosch Starter.
Bernard
Old 06-15-2005, 10:15 PM
Does the starter have a good earth to the Body? Even if the solenoid is working (clicking) you still need a good earth or the motor will not engage.
Old 06-16-2005, 02:00 AM
Didn't forget the ground cable at the back of the transmission?
Does the engine turn over by hand? (It's not stuck or stiff)?
1975 911s
1997 Saab 900s
Old 06-16-2005, 04:39 AM
Friend of Warren
What Rex said. Pull the plugs and see if you can turn the engine over by hand. If so, leave the plugs out and try turning the engine over with the starter.
Kurt V
Old 06-16-2005, 06:16 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Had the same issue. Found that we forgot to connect the large black wire to starter +.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 06-16-2005, 07:57 AM
BReyes's Avatar
Removed starter. Had it checked on bench. Perfect. Checked grounds, replaced negative side battery cable. Replaced battery.
Friend came in. With two people, checked power to Solenoid. Yes, ok. Checked power to starter. No power to starter.
Now that have no power to starter need to determine why. Anybody have a schematic diagram. Don't expect a relay to be a culprit. I lowered engine a little again, and ran my hands over the wire onto the engine. All seems fine. Took a break.
Once figure this out, engine is ready to be primed, and then it is out for a break in drive.
Thanks again.
Bernard
Old 06-16-2005, 05:33 PM
Air Medal or two
the wire (cable) comes strait from the batt.-check the cnnection again,and the grd. again (big cable) if you have pwr back to the syl. you should be able to jump it there and get it titurn over
Old 06-16-2005, 06:15 PM
BReyes's Avatar
Yes all connections tight. We did not run a jumper wire.
Bernard
Old 06-16-2005, 07:12 PM
Air Medal or two
you do not need a wire ,just use a srew driver and go accross the big terminal to the lil one and it should act like it ought to....If not take the big cable direct to the starter (be brief ) and it should take off,,how ever it will not engage your flywheel.....if none off this pruduce results your starter is junk (if for sure you batt is ok).
Beware do not run yourself over in any of these test!!!
Old 06-16-2005, 09:42 PM
BReyes's Avatar
The starter is like new, and it was bench tested today at parts store to be sure.
Bernard
Old 06-16-2005, 10:34 PM
911mot's Avatar
loose battery terminal?
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 06-17-2005, 05:45 AM
safe's Avatar
Stupid maybe , but are you sure its the solenoid thats clicking?
I had the same problem. Turned out to be the CIS clicking and there was no power to the solenoid due to corroded connections.
Magnus
Old 06-17-2005, 06:06 AM
BReyes's Avatar
Terminal tight, replaced the negative terminal. Solenoid is the click comes from , and it gets power but not the starter. Hmmm...
Bernard
Old 06-17-2005, 08:13 AM
Air Medal or two
Dose your engine turn over by hand??Are you getting votage to the syl from the key switch?is the batt grd clean and tight on booth ends??can you take and just jumper cables dwn the starter and make the eng turn over??
Old 06-17-2005, 09:01 PM
BReyes's Avatar
Battery to Starter (black) wire runs along the right side of chassis.
Bernard
Old 06-19-2005, 10:05 AM
Friend of Warren
Have you tried doing this yet??????
Kurt V
Old 06-19-2005, 02:16 PM
Air Medal or two
I think he took the day off just as we were getiing started....
Old 06-19-2005, 02:34 PM
