Wer bremst verliert
JohnJL's Avatar
Engine Case Numbers Weirdness
I obtained my core from another Pelicanite from an assortment of parts...we did a dry assembly from an assortment of parts he had from many engines. I'd appreciate some help on id'ing what I think I have here...I've tried Wayne's book and I can usually get close (the cams were right) but never 100% right. The parts on hand were thought to be an 81 and an 83. One was Euro, one was not, we thought. I chose the heads with the smaller intakes because I wanted to port them to a specific shape for my Megasquirt conversion and wasn't sure the Euros would be the right shape.
Engine case # 6313110
Engine case part # 930.101.103.4R
Cylinder heads # 930.104.328.3R
Would like to confirm what I've got so I know whats in spec and whats not.
Thanks all
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-19-2005, 02:55 AM
Engine case is from a 1981 SC engine type number 930/10.
The number you've posted for the cylinder head is a casting number not a part number - what are the valve & port sizes ?
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 06-19-2005, 03:14 AM
Wer bremst verliert
JohnJL's Avatar
Hi Andy,
930.104.328.3R looks like the part number to me, and is similar to the US heads' 930.104.028.05 in Wayne's book. But just like the engine case numbers, they're a little off his reference tables.
The valves are still in the heads, but the intake looks to be 49mm, exhaust 42mm.
Intake port is ~34.5mm, exhaust 38.2.
Believe the casting is K1926c.
thanks
John
Old 06-19-2005, 03:42 AM
Wer bremst verliert
JohnJL's Avatar
Sorry, 35mm on the exhaust port, I was measuring at the flange, not at the inside.
Old 06-19-2005, 03:53 AM
John - valve & port sizes suggest either a '77 3.0 Carrera or '78/'79 SC.
You should be able to see a date code (M/YY) embossed on the heads to the left of the K1926c.
Andy
Old 06-19-2005, 03:56 AM
If the port sizes are 34/35 it's likely to be an '80-'83 SC.
Andy
Old 06-19-2005, 03:59 AM
