Wer bremst verliert
Engine Case Numbers Weirdness
I obtained my core from another Pelicanite from an assortment of parts...we did a dry assembly from an assortment of parts he had from many engines. I'd appreciate some help on id'ing what I think I have here...I've tried Wayne's book and I can usually get close (the cams were right) but never 100% right. The parts on hand were thought to be an 81 and an 83. One was Euro, one was not, we thought. I chose the heads with the smaller intakes because I wanted to port them to a specific shape for my Megasquirt conversion and wasn't sure the Euros would be the right shape.
Engine case # 6313110 Engine case part # 930.101.103.4R Cylinder heads # 930.104.328.3R Would like to confirm what I've got so I know whats in spec and whats not. Thanks all
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Engine case is from a 1981 SC engine type number 930/10.
The number you've posted for the cylinder head is a casting number not a part number - what are the valve & port sizes ?
Andy M&W 904 ... now gone GT-style 356C ... also gone Last edited by andyjboy; 06-19-2005 at 03:25 AM.. |
Wer bremst verliert
Hi Andy,
930.104.328.3R looks like the part number to me, and is similar to the US heads' 930.104.028.05 in Wayne's book. But just like the engine case numbers, they're a little off his reference tables. The valves are still in the heads, but the intake looks to be 49mm, exhaust 42mm. Intake port is ~34.5mm, exhaust 38.2. Believe the casting is K1926c. thanks John
Wer bremst verliert
Sorry, 35mm on the exhaust port, I was measuring at the flange, not at the inside.
John - valve & port sizes suggest either a '77 3.0 Carrera or '78/'79 SC.
You should be able to see a date code (M/YY) embossed on the heads to the left of the K1926c.
Andy M&W 904 ... now gone GT-style 356C ... also gone |
If the port sizes are 34/35 it's likely to be an '80-'83 SC.
