Red face Stipped transmission mount
Hi guys. One of the transmission mount's stripped out on my 911T. It never really went tight, so I think it was pretty bad off to begin with. Now what? re-tap the hole? Is there some sort of insert I can use? There's no way I can see to drill it out and put a nut on the back, except for maybe going right through to the interior.
Jeff
'76 912E
'70 911T
Old 06-27-2005, 08:38 PM
Irrationally exuberant
ChrisBennet's Avatar
TimeSert it. The kit is expensive so unless you can borrow it, have a shop do it.
The way to avoid stripping them is to loosen the M8/13mm 4 nuts on the trans carrier before putting in the big mounting bolts. That way you can move the carrier around easily to line up the holes for the mounts.
(Remember to tighten the nuts afterwards.)
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-28-2005, 03:44 AM
Thanks Chris. The bolt was worse off than the bore, so by putting a clean bolt we were able to get a pretty good bite. I don't want to torque it to much. How tight are those bolts supposed to be?
'76 912E
'70 911T
Old 06-28-2005, 08:31 AM
Nitrometano's Avatar
Use threadlock too. Just in case.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 06-29-2005, 07:23 AM
From memory - the torque spec was 65 fl-lb; same as engine mount bolts.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 06-29-2005, 08:00 AM
After looking into the hole with a flashlight, the thread is totally gone except for the deepest mm or so.
The other mount is fine, so I'll just snug the bad one so I can limp to the shop to get it TimeSerted.
Jeff
'76 912E
'70 911T
Old 06-30-2005, 12:25 PM
