bavaria911's Avatar
Bavaria911 needs some EXPERTS Advice!!
Gents,
Need a little help .
I will rebuild my 2.4 motor in the future and if I do the job or Henry , I believe that I should replace the standard oil pump for the one in the picture. Here is what I know about the oil pump:
+ This pump was purchased new about 10 years ago and was installed in a 2.7 R/S spec engine.
+ This past spring the engine suffered the classic 4th to 3rd gear upshift resulting in an over rev and damaged valves.
+ The engine is being reconfigured and no longer requries this pump.
+ No more than 20k miles was put on this unit .
The pump is for sale, what is the going rate for one????
Also - what modifications must be done to the case...if any??
Thanks,
Bavaria
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 10-16-2005, 09:40 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The pump in the picture is an early style pump and not what I would choose if there were other options.
The 908 or 4 bar pump would be more suitable.
The case will need CaseSavers and an oil pump by-pass modification.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-16-2005, 12:45 PM
bavaria911's Avatar
Henry,
Thanks!
Bavaria911
1970 911T w/ 2.4S
RG Member # 818
Old 10-16-2005, 02:20 PM
