cylinders and pistons who made yours?
I am looking to purchase new pistons and cylinders and would like to know what you are using and if you are happy with your purchase. I would like 98mm and 10.5 to 1 but ???
what are you using???
Old 07-06-2005, 05:36 PM
1meansc's Avatar
I am using 98mm JE pistons & cylinders that I got from Jon @ EBS.
The CR is 10.5:1. Good service and reasonable cost.
The pistons are what are called the wedge type, similar to Max Moritz. Just be carefull if you are going to go with twin spark, as the second plug is not located in the correct place for these pistons. Check with Jon to see if there is a specific design for twin plug.
Old 07-06-2005, 09:40 PM
Nitrometano's Avatar
I buy a set of 95mm JE 10.5:1. I will use single plug.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 07-14-2005, 10:47 PM
who is EBS
1983 911SC
1977 911S "parting out"
Old 07-15-2005, 07:57 PM
blue82coupe's Avatar
Here's a linkwww.ebsracing.com
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 07-16-2005, 04:54 AM
magic930's Avatar
Using LN Engineering 98mm cylinders and JE pistons
http://www.lnengineering.com/index.html
Old 07-17-2005, 08:10 AM
Nickies are available from our gracious host too :-)
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 07-17-2005, 09:02 AM
Magic what do you think of your cylinders and pistons? LN is the way I am heading but I have heard of others but I have not seen any with a warranty like LN its nice to see a company stand behind its product
1983 911SC
Old 07-17-2005, 08:42 PM
65rsr's Avatar
www.omegapistons.com
Old 07-17-2005, 09:09 PM
Somewhere in the Midwest
MotoSook's Avatar
65RSR..you used the Omega?
Old 07-17-2005, 09:47 PM
65rsr's Avatar
They were made for my 3.367 RSR High Butterfly / Kugelfischer MFI engine, ti Arrow rods, and a bunch of other fun stuff.
http://www.arrowprecision.co.uk/
Stephen
Reinhold Motorsport
Old 07-17-2005, 10:13 PM
MotoSook's Avatar
Sounds like a nice build!
Old 07-17-2005, 10:28 PM
magic930's Avatar
Starlifter... I think I got one of Charles' first sets at 3.4L 98mm. I am very happy with the cylinders and have about 2500 street miles on them now.
Old 07-18-2005, 01:13 PM
MBruns for President
JeremyD's Avatar
Omega pistons - cool...
Old 07-18-2005, 01:23 PM
3 restos WIP = psycho
kenikh's Avatar
Omega looks like a prototyping shop. Sounds like big, big $$$.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-18-2005, 01:54 PM
65rsr's Avatar
Fairly big $$$ (about the same as 3 sets of Mahle's) if you're paying for the original forging, after that, the 2nd set of pistons is not too much more than a set of Mahle's, unless for some reason you fell the need for some special metal matrix pistons.
Accralite might have some applicable Porsche pistons / forgings in stock. www.accralite.com
Cool Fact: Both Omega and Accralite use Hiduminium (RR58 or 2618a) and also blend in other alloys for different reasons. Strong, lightweight, and originally developed for the Rolls Royce Merlin engines.
Stephen
Reinhold Motorsport
Old 07-18-2005, 05:15 PM
Omega makes real, real nice pistons. I've set up Nickies in the past to run with customer's Omegas, but i'm not 100% sure on how they expand in comparison with the JEs, where we have been able to snug up the clearances. I've been curious to try the forged side relief style piston (like the omega shown) over the standard slipper skirt, but again, JE states that they have to run significantly more clearance with the forged side relief style, as they run hotter (statement made by JE) and also they don't have any real world experience with those forgings on street engines.
Charles Navarro
Old 07-19-2005, 05:42 AM
Walt Fricke's Avatar
CN:
You say:
"I've been curious to try the forged side relief style piston (like the omega shown) over the standard slipper skirt, but again, JE states that they have to run significantly more clearance with the forged side relief style, as they run hotter (statement made by JE)."
Might this forged side relief affect the distribution of the cooling oil sprayed at the backside of the crown? As in little or none out to the sides by the wrist pin openings?
Interesting design, though. Is its virtue less weight?
Walt Fricke
(with some J&Es in hand and thus no $ for something else for the current engine project)
Old 07-19-2005, 07:32 PM
They do weigh less, but not a whole bunch. Something on the order of maybe 20-30 grams, tops, for the piston I was looking to have made up. Oil squirters most definately will help, but isn't a sole solution to the fact that they expand more since they get hotter. As far as oiling, we've been putting forced dual pin oilers that are machined into the piston by JE to further aide with lubrication. JE's forging on the other hand takes a twist to how they increase the strength (since it runs hotter and they tend to be used in high rpm/horsepower engines. See the attached picture for comparison vs a standard slipper skirt piston from JE:
Charles Navarro
Old 07-20-2005, 07:36 AM
