'83 911 SC 3.0 L rebuild 142,000 miles
During disassembly, I found this. This does not appear to be a fresh break. Fix with GB Weld and tighten the nut carefully or weld and tap for the stud? Thanks, Bruce
Old 03-09-2017, 12:49 PM
I had on like that, welded it up and tapped it, worked out well.
Bruce
Old 03-09-2017, 02:38 PM
Thank you, Bruce.
I live in the frontier of Montana; can any machine shop the will weld aluminum do the job? Or ship it off to, say, Ollie's?
Old 03-09-2017, 03:04 PM
prschmn's Avatar
You should be able to find a competent Al welder near you. you can use the mount as a fixture to locate the hole afterwards.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 03-09-2017, 03:42 PM
