'83 911 SC 3.0 L rebuild 142,000 miles
During disassembly, I found this. This does not appear to be a fresh break. Fix with GB Weld and tighten the nut carefully or weld and tap for the stud? Thanks, Bruce |
I had on like that, welded it up and tapped it, worked out well.
Bruce |
Thank you, Bruce.
I live in the frontier of Montana; can any machine shop the will weld aluminum do the job? Or ship it off to, say, Ollie's? |
You should be able to find a competent Al welder near you. you can use the mount as a fixture to locate the hole afterwards.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
