opening case
To install a 964 distributor you need to change the gear on the crank and for this you will need to open the case? must I go through all the machining as If I were doing a total rebuild? should I just do a total rebuild? Can you open the case, replace that gear and close it without changing anything?
This started as a top end but I started changing things 1983 911SC 3.0 with less than 100,000 |
Indeed, the crank gear must match the one on the distributor so if you want to use the 3.6 dual-dizzy, you should install the 3.6 crank gear (about $ 65).
The crankshaft must be removed so the cases must be opened up.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have the complete intermediate shaft if you are interested...
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
intermediate shaft ?????
1983 911SC 1977 911S "parting out" |
