993 longblock with PMO or other carbs
Assume I would find a really good longblock for 1800 euros (2200 $) and then be prepared to spend money on new PMOs or other carbs. How would this work for a transplant in my -72 T 911 with a restored 915 tranny.
-Additional modifications?, engine mounts, transmission changes -Additional parts I have to consider? What about the end result? The car would be used mainly for weekend driving. Originally I planned this for a 3.0 SC engine but now I am working in Italy and found this longblock with 80000km. Thankful for any input Cheers Henrik (swedish 911 owner currently in Italy)
993 Cabrio 95 (current) 993 Carrera 94, 964 C4 Cabrio 90, 911 Cabrio 87, 964 C4 92, 911 2.4T Targa 72 |
I like Orange
Last one first. The PMO50's on a 993 is great fun. Would be a real "modified" red Fiat killer.
The 915 will handle the power if you are smooth. You must fit a SC or Carrera flywheel & clutch setup to the 993. Use the 993 engine mounting bracket, it should fit straight in. G/box mounts remain. Clutch and Throttle remain too. All that's required is new fuel and ignition plumbing - quite easy. Are you planning on modifying the engine? Enjoy. Tom
“Rules are meant to be interpreted…” http://www.cafe9.co.za |
Love the "red fiat" quote!
![]() Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
You might be able to find a longblock in that price range where you are located. In the states......they are closer to $3,500 US.
Rick '78 930 |
Registered Loser
Are PMO's on a 933 really a good idea? Isn't the porsche varioram induction system and EFI superior to carbs?
Owner of a wrecked 944 |
One thing to keep in mind is that additional oil cooling will be necessary. The 3.6 does not have the engine mounted cooler of the earlier engines. This can add considerable expense to the project, especially if your early car does not have any front cooler at all. This could run you another $1500 or so. I believe the stock dual distributor can be used to trigger the ignition, but you would need a programmable advance curve, since the DME usually does that for the 993. MSD makes suitable products for this. Not too expensive from Summit Racing. I think it would be a great motor for an early car. I considered it myself when I blew the 3.0 in my '73, but found a used 3.4 locally before pursuing it. I'd want to beef up the 915 too and add some tranny cooling. Another kaa-ching, but do-able. If you're going to spin it to 7,000 RPM a lot, I'd replace the rod bolts with ARP or Raceware. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 Last edited by ttweed; 07-19-2005 at 04:54 PM.. |
Great advice from Mr. Tweed,....
![]() I'd simply add that the 3.6 distributor has no trigger in it,...it simply "distributes". That said, its possible to add a trigger to it and make it adjustable so you can adjust timing. A PMO'ed 3.6 becomes a "weapon" and the throttle response belies the HP increase. As Tom mentioned, there are internal changes one should make for durability for track use; rod bolts, valve springs, retainers usually does it.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
