Does this part go on a car?
Just finishing up and checked parts manual with engine and I cannot find item 55, a protective sleeve which apparently goes around the oil feed line.
Anybody seen this on their engines?
steve old rocket inguneer |
The later braided steel line doesn't have that sleeve
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
I like Orange
It's a heat protective sleeve, and yes, it's on most early 964's.
You can buy an aftermarket sleeve from most performance part stores. The oil pipe will eventually start leaking, and as suggested above, a good engineering hose shop will replace the rubber hose with a steel braided version for little $.
“Rules are meant to be interpreted…” http://www.cafe9.co.za |
Thanks.
