Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
I have now picked this engine up and have removed the intakes on removing the intakes I have noticed that the oil breather hose inlet has lots of fresh oil inside when I placed my finger in the hole it came out covered in oil. The previous owner reported that the plug on #2 cylinder was regularly fouled on inspecting the intake port on this cylinder it is visibly oilier than the rest however the oil is higher up than the valve the gasket between the intake and the head was really oily and the #2 intake walls were covered in a film of oil as is the rest of the intakes.
Could the smoking and increased consumption reported by the previous owner be due to oil getting into the oil breather rather than the valves stems, the previous owner did say he thought the consumption seemed to decrease as the oil level dropped. If he was overfilling would you expect a massive amount of smoke of could he just be doing it to a level where only a small amount of oil was entering the intakes?
Well this afternoon I got a bit carried away with claening up my new engine and now its stripped down to the case on one side. Must say everything looks in pretty good shape the cylinders look like they have just been freshly honed.
The heads seem in good condition with no obvious valve damage How can I tell if my pistons are badly worn or if I can just replace the rings? |
MBruns for President
Measure em... But you should be OK.
My heads looked better than yours and my guides were shot
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Banned
One thing that can be done to improve valve guides is to use a grape style ball hone on the new guide. The honing process produces a cross hatch pattern, just like the cylinders have. The cross hatch is very important because it holds oil. The oil lubes the valve guide and prevents wear.
