How could I not realize that....
... all 6 upper comression rings were broken?
I really wanted to believe that I was 'in tune' with my car, but if it weren't for the fact that the car was spewing/spraying/leaking oil from the pressure relief valve on top of the oil tank, I would have never known there was an engine problem. I thought that the engine was running great. I believe that I even did 2 track days with the broken rings, based on the over pressure oil leak, without noticing that the engine wasn't right.
Anyway, a leak down test showed very low compression in every cylinder.
So, does anyone want to guess how much I was down on power without noticing?
Stock 3.6L 964 = 247 hp
My 3.6L 964 with 6 broken rings = ??? hp
93 RS America
Old 08-18-2005, 11:49 PM
Erick
From a guy that runs a couple of early cars in the 140hp range I figured the 250hp range would be like a Canadian winter. When it gets below -20 doesn't really matter how cold it gets. Similary 200- 230- 250 what does it matter, how would you tell the difference. Don't get me wrong I'd give my right arm to be there so I'll take a stab at 200 HP that's a 20% loss.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 08-19-2005, 03:52 PM
Originally posted by stevef
Erick
LOL! That's funny.
I should have been more clear that I don't actually know how much I was down on power (didn't dyno the car before or after), but somehow I think that most people would notice power loss from 6 broken piston rings, regardless of what the starting hp was. If not, then maybe they don't need that 3rd ring after all.
93 RS America
Old 08-19-2005, 04:18 PM
Re: How could I not realize that....
Erick:
A dyno test would have shown a loss in low & mid-range torque with all those broken rings. Peak HP is not affected very much depending on many factors,....
Bottom line: you & your engine will be MUCH happier with full compression, but I'd strongly suggest that you figure out WHY the engine detonated hard enough to break the rings and prevent that from recurring.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-19-2005, 04:32 PM
Re: Re: How could I not realize that....
Originally posted by Steve@Rennsport
Erick:
Hi Steve,
Well, you've got me worried now. I had just figured that a 964 with 115,000 miles on it, and possible a decent amount of track mileage could experience broken rings. No?
Other than that, I'm not sure what causes that kind of detonation. My engine is stock, except for a 'chip' from Autothority. Have you ever heard of detonation problems with those chips? I always use Premium grade fuel (91-93 Octane in the NW). The distributor belt is intact. And the valves were adjusted within the last 10k miles.
I'm at a loss to explain it.
Erick
93 RS America
Old 08-19-2005, 04:54 PM
Erick:
Detonation in 964's is caused by several things including:
1) Insufficent octane fuels
2) Improperly programmed chip (common)
3) Broken distributor drive belt
4) Excessive carbon buildups on pistons and combustion chambers. This raises affective CR as well as generates hot spots
5) Excessively lean fuel mixtures (poor chip)
I have seen problems with their chips when operated on West Coast gasolines and the outcomes are all identical to yours.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-19-2005, 08:01 PM
Super Moderator
cstreit's Avatar
Steve is right on the money (imagine that for such a rookie, haha). My first thought was crappy fuel, but I'd be wary of some of the chips out there... They get pretty damn agressive and won't tolerate marginal fuel with some of the high advance curves they use.
As Steve sez... definitely start to think about the cause, there is no reason all 6 should be broken by "normally" hard use.
Does your car have the distributor vent modification?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-19-2005, 09:57 PM
Erick:
You've seen problems with Autothority chip on 92-93 octane West Coast gas? And I thought 92-93 was good! No? Well I'm taking that chip out then.
So how do I know what a good chip is, because I've heard that chipping these engines can make a decent power increases. Is there always a detonation cost? Should I only use chips that are burned to my particular engine on a dyno?
93 RS America
Old 08-20-2005, 12:03 AM
Yes, I have the vent mod... and the belt is still intact. Although I think that I'll replace it now. Just in case.
93 RS America
Old 08-20-2005, 12:05 AM
Yes, I have. IMHO, some of their software has been too aggressive in the low & mid range for the fuel we have combined with hot weather. Thats a sure recipe for detonation.
Indeed, a properly made chip enhances throttle response and mid-range torque but the software vendor must take into account the local particulars such as fuel grades and any engine modifications that has been done. Failure to do so creates the problem that you have.
A properly programmed performance chip does NOT trigger the engine into detonation.
Unless your engine is highly modified and therefore would require custom programming, a good chip provider should have software that will enhance the performance of your largely stock 3.6 on 92 octane fuel. I do recommend that people mix some unleaded race gas for DE events no matter what software one uses.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-20-2005, 02:15 AM
Steve,
That's interesting. What ratio of race gas to 91 octane gas should be used for track days?
Erick
93 RS America
Old 08-21-2005, 02:56 PM
Erick
FYI, I've got about 2900 lbs (after some weight loss projects) to haul around. What about your 140hp car?
93 RS America
Old 08-21-2005, 03:49 PM
SUMMARY
1) Insufficent octane fuels - Use 92-93 octane for street and track
2) Improperly programmed chip (common) - Autothority chip
3) Broken distributor drive belt - No, it's intact
4) Excessive carbon buildups on pistons and combustion chambers. This raises affective CR as well as generates hot spots - Certainly there was a layer of carbon built up on the pistons, but it didn't seem excessive from what I've witnessed before. Anyway, that's been cleaned up now.
5) Excessively lean fuel mixtures (poor chip) - Autothority chip
93 RS America
Old 08-21-2005, 04:07 PM
Erick:
I would add one more thing; any vacuum leaks in the intake system introduces air that is not metered by the airflow meter. This generates a lean condition that can trigger detonation. I would go over the entire intake system, rubber boots, and ALL hoses to make sure that there is not a vacuum leak.
One tests for these issues using either a can of spray carb cleaner with a long nozzle or a bottle of propane and a wand. With the engine running, any introduction of these fuels changes the idle speed when they are sucked into any vacuum leak and a sharp ear can detect that.
You can find a fuel blending matrix chart I posted at http://www.rennsportsystems.com/2a.html.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-21-2005, 06:15 PM
jpahemi's Avatar
AFR readings may indicate what's going on with the mixure and what the chip is doing with the fuel curve.
j.p.
Old 08-21-2005, 10:02 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
All great points. Even Steve (the rookie) was on the money . I would recommend the NBD dual chip to get the best of both worlds. Run the stock setting for daily driving on pump gas and switch to performance for track driving when you have access to high-octane gas. Remember, in SoCal premium is only 91 octane. That is marginal to say the least.
BTW: My gaskets for the intake manifolds on my 3.6 were all leaking and hardened. I am sure yours will get replaced during the rebuild.
Cheers,
Ingo
http://sswl.di.com/~ingo/Chipping.htm
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-21-2005, 11:40 PM
vichang4's Avatar
I broke the rings on cylinders 1, 2, & 3 in my 50,000 mile 930 because of clogged fuel injectors. Is this a potential problem on 964's?
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 08-22-2005, 04:19 PM
ischmitz's Avatar
Hm,
as soon as there is less fuel in the barrel than what the DME comanded (clogged injectors) or more air (intake leak) than what the DME metered and calculated the fuel required for you have a lean condition. This results in detonation (aka knocking) which hammers rod bearings and breaks rings.
So in simple works: YES but the Turbo's are probably more sensitive since boost adds more margin for the mixture to go out of whack.
Ingo
Old 08-22-2005, 05:52 PM
Thanks guys. I'm having the fuel injectors cleaned and rebuilt. And I'll check for vacuum leaks in the intake system. Does anyone know where to get a "wand" for a propane tank to test for leaks?
Thanks for all of the valuable info.
Erick
93 RS America
Old 08-23-2005, 06:58 AM
ischmitz's Avatar
Erik, brake cleaner, carb cleaner, starter spray all work fine.
Old 08-23-2005, 07:39 AM
